88 yota ... HELP! Doesn't run right once warmed up
Old Jul 4, 2009 | 06:21 PM
  #41
BluVudu's Avatar
I didn't get to check anything today since it rained ALL day but tomorrow I'm going out to check for air leaks and run by Advance and put the new coolant sensor in. I drove it to my parents today and it ran great for a 160 mile round trip. I am still having issues getting it started. It turns over and I have to step on the gas, which is not supposed to happen in EFI, and when it starts it dies about 4 times before it finally starts. Now when it finally starts, it runs great.
Old Jul 5, 2009 | 12:50 PM
  #42
Kiroshu's Avatar
yea thats coolant temp sesnor with the starting issue, possible cold start injector... but i'd say coolant. keep posted.
Old Jul 5, 2009 | 04:31 PM
  #43
BluVudu's Avatar
The way I have to start it is to plug the coolant temp sens in and start it... starts perfect. Then get back out and unplug it. The only other thing that I've noticed is that it idles higher and when I let off the throttle to shift, it comes down pretty slow. Other than that, my baby is finally running pretty well. Not sure what's causing the idle to be higher. I'm replacing the coolant sens tomorrow and checking for leaks lol I felt lazy today so didn't do much except sell a bed liner. I was just looking on the net for a cold start injector and all I'm coming up with is a cold start valve... is that it?
Old Jul 5, 2009 | 09:47 PM
  #44
Kiroshu's Avatar
Nah its supose to be called a cold start injector. some places may call it a cold start valve. throttle may be sticking a little bit try cleaning your throttle plate with carburator cleaner. Anywho keep posted.
Old Jul 5, 2009 | 10:01 PM
  #45
BluVudu's Avatar
ok thanks dude... I'm gonna do some stuff to it tomorrow and see what happens. I appreciate all of the help man.
Old Jul 7, 2009 | 02:54 PM
  #46
BluVudu's Avatar
I went out this morning and put the new coolant temp sens in it and she fired right up and is running great. I have a slight puff in the exhaust but I haven't gone though it yet to see if it has leaks. I'm looking for a header to put on it now. I had to run somewhere quick this morning so I haven't sprayed the fuel plate with cleaner yet but hopefully it will help. I may have to bump the idle down a bit.
Old Jul 18, 2009 | 05:56 PM
  #47
Kiroshu's Avatar
Hey thats great i figured it was coolant temp. sorry its been a while since i posted been busy. Said theres a puff of smoke on start up? what color smoke? Yea clean your throttle plate and set idle. idle for the 22re should between 750-800 but anywhere under 1000 is just as good.
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
smiley52
Jul 11, 2015 05:16 AM
icentropy
Jul 9, 2015 02:12 PM
karbin
Jul 5, 2015 11:37 PM
