88 yota driver front making awful rubbing noise
Old Nov 27, 2023 | 04:04 PM
Jayburn93's Avatar
My 88 front driver is making an awful Rubbing/grinding but more so rubbing sound when locked in 4x4 it's mind blowing, put new wheel bearings in so it's not the bearings. Even when hubs are locked and put into 2wd front driver still makes sound and slight vibrations any help would be very appreciated.
Old Nov 27, 2023 | 04:44 PM
cashmoney00's Avatar
Cv joint?
Old Nov 27, 2023 | 07:14 PM
Jayburn93's Avatar
Originally Posted by cashmoney00
Cv joint?
it sounds like no CV joint I've ever heard before unless this is just some fluke CV joint going bad.
Old Nov 27, 2023 | 10:22 PM
Andy A's Avatar
Solid axle or ifs? If ifs make sure the steering knuckle bushings have plenty of grease. They can make some terrible noises especially as it starts to get colder.
Old Nov 28, 2023 | 04:18 AM
keycw's Avatar
5 Year Member
if its only doing it in 4x4 and not doing it in 2wd..then the issue is rotational. sounds like youve narrowed it down to a bad axle or improper assembly..pull the axle, inspect, reassemble.
sirlegsalot
Mar 5, 2012 10:25 AM
neatname
Apr 16, 2007 05:38 PM
Ilovemountains
Feb 14, 2007 03:08 PM
davemacneil
Oct 24, 2006 11:18 PM
1Runner
10
Jan 4, 2003 04:29 PM
