88 Toyota 4x4 pickup 22re 4 cyl non-turbo
Old Jan 28, 2023 | 11:02 AM
Justinsane's Avatar
Truck starts, runs for about a second then dies and smells like fuel. For a few days prior it was running but having trouble starting and while it was running it would have power loss and surges with an occasional stutter and backfire. I was told that it was the map sensor but I can't seem to even find a map sensor on the engine
Old Jan 28, 2023 | 11:16 AM
JoeS's Avatar
Maybe they meant the MAF sensor which is that box sitting on top the air filter box. I'm pretty sure 84-88 22re didn't have a MAP sensor.
Old Jan 28, 2023 | 12:35 PM
wallytoo's Avatar
not an MAF. the box is an AFM/VAFM. it does not measure the mass of the air passing the sensor (an MAF) but rather the volume of the air moving (VAFM).
Old Jan 28, 2023 | 01:37 PM
scope103's Avatar
"runs for a second then dies" is the classic sign of a problem in the COR-VAF circuit. https://www.yotatech.com/forums/f116...-quits-312747/ Usually doesn't leave a fuel smell, but trivial to diagnose (and get out of the way).
Surges, stutter and backfire are unlikely to be due to a VAF problem. I'd check ignition timing. Then use the inductive pickup on each plug wire to check for a plug not firing.
Old Jan 28, 2023 | 02:42 PM
JoeS's Avatar
Thanks for the correction. Got my acronym messed up for that box on the air filter box.
yotapwru
Washington
Oct 22, 2015 08:51 AM
obedb708
Jun 15, 2015 06:28 PM
chalk400
Apr 11, 2015 06:02 PM
country lambo
Apr 6, 2009 12:59 PM
4x4phil
Apr 27, 2008 10:39 AM
