88 toyota 22re , no power?
Old Feb 25, 2014 | 04:27 PM
Tommahark's Avatar
Question 88 toyota 22re , no power?
Truck will not come on, no lights no sounds. Battery , starter and alt fine. What would be the most likely cause of this?
Old Feb 28, 2014 | 07:32 AM
Jbowls's Avatar
Sounds like a wireing nightmare? I would check any ground wires then trace the hot wires. Checked all the fuses?
Old Feb 28, 2014 | 08:33 AM
masterchiefhasayota's Avatar
Check efi fuse, maybe even test the starter relay. see if you can pull a code on it. Test the circuit opening relay. If that doesn't function, the gas pump wont turn on giving the engine the gas it needs to start.
Old Feb 28, 2014 | 08:34 AM
Romans117's Avatar
Main fuse. Other fuse and the other fuse
DacodaYota
Sep 2, 2015 02:13 PM
Sandman
Jul 23, 2015 08:15 PM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
toy89yota
Jun 24, 2015 01:18 PM
nyk08trx
Jun 18, 2015 09:01 PM
