88 runner wont go
Old Apr 21, 2007 | 06:59 AM
dangrous toys's Avatar
88 runner wont go
pulled runner out of shop now it will not start. It is a 22re 5 spd
Old Apr 21, 2007 | 07:01 AM
4bytruckin's Avatar
and.......... what did you have done, why was it there, how many miles on engine , no start or will star but won,t move. 4x4 or 4x2 . is the trans case in nuetral or driveshaft hooked up. these are things we need to know to help you
Old Apr 21, 2007 | 07:08 AM
i had nothing done it is my shop in my yard. it has 257,654 km on the engine, it will roll over but not start.it is a 4x4(never seen a 4x2 runner)
Old Apr 21, 2007 | 07:27 AM
4bytruckin's Avatar
look at fuel and spark. pop of the panel under the back seat over the fuel tank. hold a hand on it to see if you feel it vibrate as you turn the key. if yes see if your getting spark to distributor and spark plugs. also try ether. it might just need a good sucktion through the line.
might be out of gas
4bytruckin's Avatar
and they made 2wd runners
Old Apr 21, 2007 | 09:09 AM
got the runner to start.But when i shut it off it will keep running.until i pull off the afm wire connector then it shuts off????????????????
Old Apr 21, 2007 | 01:50 PM
4bytruckin's Avatar
ignition module is shot. replace and give truck to me
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
