88 3.0 fuel pump not working
Old Jan 22, 2008 | 07:48 AM
thook's Avatar
Originally Posted by 88yotadad
Yes I tested the jumper wire and only had 0.08 of a volt. The same as at the pump.
What about the flow meter?
If you're only getting .08v's at the diagnostic port, it's nothing to do with the airflow meter. You have a voltage leak/break somewhere between the battery and the diagnostic box.
What's the voltage readings at the fuse box on any of the fuse? You may have a loose connection or corrosion.???
Your fusible link, I do believe, will be the 80amp fuse in the fuse box. Test there for 12v's.
http://www.toyota-4runner.org/showth...threadid=33939
There's a link for a pic of the fusible link in that thread. And now I know, too. I've seen that sucker millions of times, but didn't know that's what is was.
Old Jan 22, 2008 | 10:03 AM
88yotadad's Avatar
That is what I thought also. I ran out of time yesterday.(damn work) Just having breakfast while it warms-up outside as it was -7 last night but the sun is shining now.
Roger
Old Jan 22, 2008 | 10:26 AM
MSR's Avatar
MSR
You never said if you are getting 12v to the ciruit opening relay its the black 14 gauge wire not the small black. This should be hot when key is on. It comes from the ecm.
Old Jan 22, 2008 | 11:15 AM
88yotadad's Avatar
I never checked the wire to the circuit opening relay. I'll do that next.
What is the relay in the fuse box under the hood called?
Power going to my fuses is good.
Old Jan 22, 2008 | 12:06 PM
  #25
88yotadad's Avatar
no I am not getting 12Vs to the ciruit opening relay.
Looking at the pics of the relay ciruit; I think it is the +B wire.
By looking at the ciruit pics I think the next relay is the EFI main relay.
Is the EFI relay the relay under the hood or at the fuse panel at drivers kick panel? My Hanyes book says for up to 88 the 1 behind kick panel and for after 89 under the hood. I have relays in both places.
Old Jan 23, 2008 | 08:49 AM
  #26
88yotadad's Avatar
The map on top of the fuse box under the hood is wore off so I don't know what the relay in the fuse box is called.
Old Jan 23, 2008 | 09:25 AM
  #27
thook's Avatar
That's the EFI main relay. There's a 10 amp fuse nearby....should be right next to/before it...that is the EFI fuse. You should be getting 12v to that fuse. If not, you're not getting 12v to anything beyond it; the main relay, COR, etc.
You said, though, the fuse tested good. Did you just test for continuity or for voltage, too?
Old Jan 23, 2008 | 10:32 AM
  #28
88yotadad's Avatar
I checked the fuses for continuity and voltage and they where fine.
My book shows a different pin layout for the EFI relay so un sure when testing. I looked at the manual on line from the link but could not find the right test. I'll look again.
Old Jan 23, 2008 | 11:02 AM
  #29
88yotadad's Avatar
The EFI relay has 4 pins and I have continuity between 2 pins so I'm sure it is fine.
What about the ECU?
Old Jan 23, 2008 | 03:54 PM
  #30
thook's Avatar
So, your relay is not similar at all to this, eh?
http://personal.utulsa.edu/~nathan-b...95efimainr.pdf
The ECM.....well, if I had any knowledge of how your is designed or had something to look at I could tell you more. Suffice it to say if you knew which terminal on your ECM was for the fuel pump circuit, you could certainly test it. Let me ask Pete f to look at your thread. He has an '89 and may have a manual for it or know which is which.
Old Jan 23, 2008 | 04:12 PM
  #31
nate V's Avatar
the COR is under the pass side kick panel.
The solid blue wire is a strait run from the relay to the fuel pump.
I bet you have a break in there some where
good luck
Old Jan 23, 2008 | 04:24 PM
  #32
thook's Avatar
He's not even getting enough voltage to the COR.....which he's already located.
Old Jan 24, 2008 | 06:04 PM
  #33
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
fuse box map
I have an 89 and here are some pics of my fuse box in the engine passenger wheel well. Sorry for the left and right view I only have my phone camera.[IMG][/IMG]
That's the left side and here is the right
so I hope this helps you.
Old Jan 24, 2008 | 11:30 PM
  #34
88yotadad's Avatar
Thanks, I hope to get back at it on saturday.
Roger
Old Jan 25, 2008 | 03:24 AM
  #35
pete f's Avatar
Roger
One test I did when trouble shooting my recent problem that can rule out a bad efi relay is with the key off I pulled the relay. Then I turned the key on and when put it back in I could feel and hear it energize the efi system in the engine. I would also check for a short or broken wire with my multi-tester at the battery.
http://personal.utulsa.edu/~nathan-b.../1generali.pdf
I used the continuity and resistance test on be-4 this test will rule out a short or broken wire in the system.
Good luck!
Old Jan 26, 2008 | 09:27 AM
  #36
88yotadad's Avatar
I have checked the wires at the battery. I dropped the main fuse(80amp) and tested the wires on both sides. All where Ok.
Old Jan 26, 2008 | 11:25 AM
  #37
pete f's Avatar
My EFI relay is 12 volts 22amp round fuse there is an 80 amp fuse in the fuse box passenger side engine compartment but that is for the alternator. Which one did you test? Did you test your EFI round fuse?
Old Jan 26, 2008 | 01:24 PM
  #38
88yotadad's Avatar
I have not tested any round fuses. Where is the 22amp EFI fuse? Maybe that is the one I have been missing.
Old Jan 26, 2008 | 02:22 PM
  #39
88 flatbed's Avatar
where exactly is the "COR"?
Old Jan 26, 2008 | 07:18 PM
  #40
pete f's Avatar
This is your EFI relay. It is located passenger front wheel well in the engine compartment. When I was trouble shooting my problem I pulled it with the key off then I turned the key on and put it back when I did that I could hear and feel the relay work. I could hear the efi system energize.
