87 Yota. Can you identify this bracket?
Old Jul 10, 2022 | 08:49 PM
rob8steak's Avatar
Hey everyone,
Got an 87 pickup 2wd that was sold to me in pieces. I got the engine together and I need help identifying this bracket. Please let me know if you can identify it.
Thanks a lot!!!!
Old Jul 10, 2022 | 11:26 PM
SomedayJ's Avatar
Power steering bracket?
Almost at the bottom of the page:
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Old Jul 11, 2022 | 08:09 AM
rob8steak's Avatar
SomdayJ
I think you might be right....it definitely isn't the bracket that holds the pump but looks like a supporting bracket that goes underneath it.
Thanks!!!
Old Jul 11, 2022 | 10:54 AM
JoeS's Avatar
My 86 2WD has three separate brackets for the PS pump. The front bracket is a L-shape and has one bolt hole for the pump and one hole for the tensioner pulley bracket. The rear upper bracket is a L-shaped and has one bolt hole for the PS pump. The rear lower bracket is straight that has one bolt hole for the PS pump. None of them look like that one, but the front bracket does have a similar semicircle for the PS Pump center shaft housing to protrude to clear for the pulley.
Old Jul 11, 2022 | 12:57 PM
rob8steak's Avatar
Hey JoeS
Thanks! You are correct. I got an 86 with power steering but it's hard to see that bracket so I wasn't sure. I knew members here would know. Appreciate you taking the time to help.
Here is a little eye candy. .020 over bore. I cut no corners. Replaced all the vaccum lines, and OEM parts where possible. I even replaced aftermarket bolts lol.
Mattluke1
Oct 11, 2015 05:33 PM
pholife
Feb 3, 2012 07:22 PM
Dexter350k
Dec 16, 2007 05:44 AM
haschen
Mar 10, 2007 05:01 PM
newjerseyredneck
Mar 14, 2004 10:59 PM
