86 toyota truck front suspension
Old Dec 18, 2010 | 02:39 PM
backyardfun's Avatar
Thumbs down 86 toyota truck front suspension
i have a 86 toyota truck. i'm looking for ideas how to build up my front suspenion. i use it for plowing snow. no road use at all. its far from being street legal. when i pick up the plow it squats BAD! so any idea is not crazy as long you think it will work. so please give me a idea.,,
UPDATE; thanks for all replies. there all good but, i don't care how it rides. it can ride like a lumber wagon... i doesn't not leave my yard. i just don't want it to squat when i pick up the plow. i was thinking about putting metal pipe in place of the shocks?
Old Dec 18, 2010 | 02:59 PM
boristheblade's Avatar
Crank up the torsion bars.
Old Dec 18, 2010 | 03:00 PM
xxxtreme22r's Avatar
crank torsions or go with the thicker sway-a-way torsions.
Old Dec 18, 2010 | 03:14 PM
camo31_10.50's Avatar
thicker torsions would be better.
and prolly some HD shocks with better valving.
more aggressive valving=stiffer shock=better load handling...right?
Old Dec 18, 2010 | 05:32 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
V6 bars are supposed to be more HD...
I would not crank them up...
Downey had forged bars, not the cast like Sway-a-way and others.
Not necessarily that that's a good or bad thing, because the ride could be harsh. But for your plow, I wouldn't worry about it.
Some say Jim still has stuff. I'd message him or look around. You might still be able to find a pair.
EDIT: IIRC, the OME's were either 1mm smaller, or 1mm larger than stock... But they were designed for ride and flex. To my knowledge, not a duty cycle like holding up a snow plow.
Old Dec 19, 2010 | 04:41 AM
muddpigg's Avatar
If you can't find thicker T-bar might want to consider some sort of coilover shock to assist stock T-bars. Probably give you more options.
Old Dec 19, 2010 | 04:51 AM
no one make a direct replacement coilover for the IFS trucks, might have to make your own mounts.
but that's a good idea.
matrad
Aug 26, 2024 08:21 AM
truckmike26
Jul 24, 2024 10:24 AM
6th Gear
19
Dec 10, 2019 07:31 AM
HBoss
Jun 29, 2002 12:14 PM
