86 Carburated Pickup Power Adders?
Old Oct 4, 2008 | 07:32 PM
Skitzo Yota's Avatar
Hey, My name is tommy and im not very familiar with little trucks at all. I have been into muscle cars for several years and am sad to say all i really know about is big blocks. I have just purchased a 1986 Toyota Pickup with a regular 22r carburated motor. I bought the truck for 600 dollars from an old farmer and it runs like a top (for its age). I am not really interested in mud slinging or rock crawling because it is just a rwd truck. All i want is a fun little ride with just enough power to have a bit of fun with. Can anyone please suggest simple power adders that would get the job done while still being easy on the wallet. I dont have the biggest budget.
Thnx alot
-Tommy-
Old Oct 4, 2008 | 07:46 PM
abecedarian's Avatar
lesseee....
header/exhaust
gears
cam
Old Oct 4, 2008 | 07:52 PM
What about turbos,,, Do you know of any turbo kits for this motor.
Old Oct 4, 2008 | 07:58 PM
ozziesironmanoffroad's Avatar
should have got one with the 22rte... too much of a pita to retrofit a turbo to a non-turbo motor. or convert it to fuel injection and get the 22re supercharger from LCE... 2500 bucks for the SC though
Old Oct 4, 2008 | 08:02 PM
yeah, the re or the turbo would be great, but who could pass up any practically mint yota for 600 bucks..
Old Oct 4, 2008 | 08:05 PM
well, with a bit of work, a 22rte exhaust manifold and turbo could be adapted to a blow-through configuration. not a perfect solution, but with an aftermarket ignition system with boost retard and knock sensing should be able to boost you 20 hp or so over stock safely
spend a bit more and convert to full engine management system, ditching the carb, and maybe pull 30-50 hp over stock
rebuild with forged pistons, aftermarket EMS (as above), should be able to double stock hp, intercool and maybe a tad more.
Old Oct 4, 2008 | 08:08 PM
thnx guys, do you have any ems suggestions?
Old Oct 4, 2008 | 08:13 PM
www.sdsefi.com
Old Oct 5, 2008 | 12:28 AM
Matt16's Avatar
Smaller tires would improve your effective gearing for better off the line performance. 22Rs and 22REs like to be revved
Old Oct 5, 2008 | 03:44 AM
do you know the factory red line?
Old Oct 5, 2008 | 07:48 AM
eatmorechicken's Avatar
Pretty much where ever the valves start floating. That motor can take it
Old Oct 5, 2008 | 09:27 AM
http://www.toysport.com/Technical%20...tech_notes.htm
a little ways down the page are some suggestions for building up.
Jun 1, 2021 01:51 PM
crashburnoveride
Aug 28, 2015 09:20 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
Nickdigg
Jul 7, 2015 06:04 AM
