86' 4Runner 22re EFI Head Gasket replacement
Old Apr 2, 2010 | 09:48 AM
MyBlueToy's Avatar
All is not well, the two rear exhaust bolts are stripped in the head. Anyone have an opinion of what to do? I heard a bit about Heli-coil.
Old Apr 3, 2010 | 08:04 AM
MyBlueToy's Avatar
If I take the exhaust manifold off will I have enough room to drill out what is left of the existing threads? Also what is better hand tapping or with a drill? I have the Heli-coils, when I went to Toyota to pick up my new OEM thermostat, I enquired about the Heli-coils and they had some extra and just gave them to me. Napa sells a kit for $40, but I think I can get away with doing it for less. I just need to get the right tap, 10Mx1.25. All help is appreciated, thank you.
Old Apr 3, 2010 | 08:27 AM
92 TOY's Avatar
I would say try to back it out 1st....
my neighbor did this for me when i snapped on on the thermostat housing but eneded up drilling it out...but i would say soak it with pb blaster 1st and try a tap, then drill.
i'd wait to see what others say too....
Old Apr 3, 2010 | 08:54 AM
MyBlueToy's Avatar
The bolt is all the way out, the threads in the aluminum head are stripped away.
Old Apr 3, 2010 | 09:04 AM
  #25
92 TOY's Avatar
ahhhhh, I see now.
not sure about tapping aluminum......out if my realm of knowledge, sorry man.....good luck to you though.
Old Apr 4, 2010 | 06:55 AM
  #26
MyBlueToy's Avatar
Just installed the OEM T-stat, and on Monday I'm going to napa for a Heli-Coil kit. Want to make sure I have the right tools.
Old Apr 4, 2010 | 08:04 AM
  #27
92 TOY's Avatar
from Toyota?...how much for one of them? i wanna gets me one of them.
Old Apr 4, 2010 | 08:37 AM
  #28
PismoJoe's Avatar
Didn't your machine shop fix any/all messed up threads in your head?
Old Apr 4, 2010 | 08:44 AM
  #29
MyBlueToy's Avatar
$15.30 plus tax, from a Toyota dealership part #90916-03078.
Old Apr 4, 2010 | 08:48 AM
  #30
MyBlueToy's Avatar
Apparently they didn't check them. I only knew when putting it back together, water under the bridge. Monday I hope to have the Heli-Coil kit and finish it.
Old Apr 4, 2010 | 08:53 AM
  #31
92 TOY's Avatar
thanks..............
Old Apr 4, 2010 | 08:57 AM
  #32
MyBlueToy's Avatar
They did have the 2-valve t-stat, part # 90916-03070. That was like $35-$37. Interesting how it has two valves. Has anyone used that one before and how is it going for you.
Old Apr 4, 2010 | 08:59 AM
  #33
PismoJoe's Avatar
no big deal, seams like you know what to do on the heli coil route. Hope you get her runnin soon!
  #34
92 TOY's Avatar
Roger (4crawler) recommended it, I guess it's a fail-safe.
Old Apr 4, 2010 | 09:04 AM
  #35
MyBlueToy's Avatar
Thanks, PismoJoe and 92 TOY.
Old Apr 5, 2010 | 01:10 PM
  #36
MyBlueToy's Avatar
T-stat is in and works, now I just am looking to borrow a right angled cordless drill to do the heli-coil. The truck sounds great besides the exhaust leak.
Old Apr 8, 2010 | 02:54 AM
  #37
MyBlueToy's Avatar
Well this should have been checked before assembling the motor. But now that the motor is assembled, I have to become creative and tap out the head. I will be doing this on friday, thinking of rotating the engine to get a better look at it.
Old Apr 8, 2010 | 07:31 AM
  #38
hilandfrog's Avatar
The 2 valved thermo thing....
Isn't it just an extra hole drilled to allow some movement and lesson pressure "just in case" ?
I thought there was a write up on these little holes somewhere on here?
Same thing or am I mixing lemon aid and milk again....
Repo
Old Apr 8, 2010 | 07:47 AM
  #39
MyBlueToy's Avatar
Repo
Here is a link http://www.4crawler.com/4x4/CheapTricks/index.shtml just scroll down to thermostat. Great help to me on a number of things that were wrong with my 4runner.
Old Apr 8, 2010 | 10:24 AM
  #40
rogerman's Avatar
wow man you are fast! how is it going so far?
