86-2x4~22R idles perfect then drops outta nowhere
Old Jan 26, 2023 | 06:38 PM
Fm900's Avatar
About 5 minutes into every drive, come to a lite, idling perfect, drops idle almost to a stall, outta nowhere for a couple seconds, but doesn't stall...I hit gas, to get it back up, then it's fine. This has been doing this for years...have no clue what it is but it's annoying, help, help? It only does it one time per trip, seems always same, 5 min. Into drive. Thanks!
Old Jan 27, 2023 | 09:22 AM
Fm900's Avatar
Consider this
Low compression when cold
Could also be fuel pressure causing float bowl level to drop.
Leaning the mixture
Cold engine needs a richer mixture to overcome cold combustion chamber temperature
Once warm, the lean mixture is ok
Friend said
Soulprogression108
Mar 13, 2022 08:36 AM
FUNrunner87
Jan 13, 2012 09:14 AM
KegKiller
May 9, 2007 01:52 PM
Charger92
Feb 28, 2006 04:29 PM
