86 22r doing some very odd things(runs better without third cylinder??)
Old Jan 25, 2016 | 08:34 AM
18witha86's Avatar
I was recently given a 1986 Toyota pickup (22r) with a rebuild (75000 miles) by my mother.
This is the truck I learned to drive in and really want to fix it up for nostalgia and a first yota of my very own. I am deffinatly a newbie.
About six months ago It started losing power and has a sort of misfire sound that progressively turned into a loss of almost all power and the motor shaking violently when idling.
I checked the distributor and the plugs (slight black buildup on 3 and 4) and made sure the timing on the distributor was on the correct tooth and lined up at TDC #1.
The weridest part is it smoother without the #3 plug hooked up. Please help me as I love this truck and hate to see it hurting haha
Old Jan 25, 2016 | 09:50 AM
mct75's Avatar
It sounds like your plug wires aren't reversed or anything since it was running fine. I'm going to suggest a compression test first off.
Old Jan 26, 2016 | 06:41 PM
18witha86's Avatar
I ran compression tests and found I had good compression on 1,3,4 but 2 had 0 psi. Maybe a blown piston ring or a bad valve? I also regapped the plugs and played with the distribution again to no avail
Old Jan 27, 2016 | 05:20 AM
mct75's Avatar
A stuck valve should be easy to see with the valve cover off, otherwise do a leakdown test and check your coolant/oil for contamination.
Old Feb 6, 2016 | 09:44 PM
tazmaniac_37752's Avatar
You could have a blown head gasket between the #2 cylinder and a water or oil port!
yotapwru
Washington
Feb 15, 2019 11:47 AM
tj884Rdlx
12
Jun 18, 2016 04:19 PM
Chick-N-Picker
Oct 29, 2015 04:19 PM
johnj
Oct 29, 2015 01:24 AM
Mike hayward
Oct 28, 2015 10:24 AM
