854x4's 22RE Rebuild Thread
Old Jun 25, 2009 | 01:38 PM
iamsuperbleeder's Avatar
Originally Posted by Junkers88
Jesus bleeder that looks so nice it makes my soul sing. Well done brother.
you haven't been watching my thread, have you
lol
thanks buddy!
Old Jun 25, 2009 | 01:57 PM
Junkers88's Avatar
lol
thanks buddy!
I've been watching....... I'll just hold all my comments until I see the video of that rig fired up and running.
All joking aside man I am damn proud of you for taking on such a large task on a vehicle that I know you hate not being able to drive.
Old Jun 25, 2009 | 03:22 PM
lol, hopefully very soon; the long block's getting set in next week, and then things will really start to come together
yeah it's killing me not to be able to cruize around in my baby... I feel so insignificant in this stock little itty bitty blue 2wd GMC Sonoma
t'will be a glorious day to get back 'hind the wheel of thy Yota
Old Jun 25, 2009 | 05:57 PM
HAWK4295's Avatar
I forget wich bolts I used for mounting the block to the stand they came off of the motor somewhere, I think the cam bolt is just right and I have 3 '85-'86 blocks here, so I believe I used a couple cam bolts and a couple Bell Housing Bolts.
Hawk4295
Old Jun 25, 2009 | 06:24 PM
  #25
HAWK4295's Avatar
I wish I had known about your rod, I have atleast a dozen rods here I'm not ever going to use. They're free for any Yota luver!! Also have Cranks (2) same deal!!
I used PermaTex ULTRA SLICK engine assembly lube Item # 81950 It's real slick and STICKY!! Reminds me of bar and chain lube for a chain saw, betcha could use that stuff too.
HAWK4295
Old Jun 25, 2009 | 06:46 PM
  #26
Hawk4295
I had to run down to the hardware store and pic up some long bolts and a bunch of washers, cause my stand is ghey
Old Jun 25, 2009 | 07:18 PM
  #27
HAWK4295's Avatar
I plan on trying this method next week, when the time comes to get that bearing out of the crank
Looking good man! What color are you spraying on the block?
I was trying to copy an LC Engineering motor, inside and out, so the block is black and the valve cover is Red.
I also installed a dual timing chain conversion with an adjustable cam gear, and METAL timing chain guides instead of the plastic ones. I've replaced TOO DAMN MANY plastic timing chain guides!!!! I wish I'd known about them years ago!!! They're plastic/rubber covered metal....
When you use grease for removing pilot bearing, the dowel HAS TO BE sooo close to the size of the hole, but can't be grabbing the bearing, if it's too small you'll have grease coming out between the bearing and the dowel, if it's nice and tight the grease WILL push the bearing out.
My machine shop boiled the block and bored it 80 over for $125.00...OH YEAH, they painted it TOO!!! Head Porting and valve job was $75.00
I had to clearance the block inside. When we turned the crank around #1 and #4 hit the side of the block!! Wasn't too bad though, to get the Stroker Crankshaft to work.
I also put in a remote oil filter kit and an oil cooler in front of radiater. Power steering fluid cooler too, with AMSOIL ATF in the system.
Break-in was done with Castrol GTX 20W-50 oil was changed at 20 miles exactly, after WOT runs up to 60mph and engine braking i.e. let off gas pedal, at least a dozen runs up to 60 and let offs. (sets the rings properly)IMO. Then I changed it again after another 100 miles, then again after another 100 miles or so. (Filters each time also)
I'll be switching to AMSOIL (ZINC) 20W-50 or AMSOIL RACING 15W-50 after another oil change. Both are SYNTHETIC as are all of AMSOIL's lubes. I already run AMSOIL ATF in power steering and AMSOIL severe gear 75W-110 in transmission and transfer case, and severe gear synthetic SAE 190 in differentials. (5.29's W/ LocRights)
Also had to have tranny rebuilt, needed a new 3-4 slider and hub gear, new synchros since it was open, and a new input shaft and bearing, new midshaft bearing, all new seals.
HAWK4295
Old Jun 25, 2009 | 07:29 PM
  #28
HAWK4295's Avatar
I used ARP fasteners; ARP Head studs, ARP Main cap studs, ARP Rod bolts. I just felt the strength was worth it. (replacing stock) That may be where I got the bolts from for the stand...
HAWK4295
Old Jun 26, 2009 | 11:07 AM
  #29
854x4's Avatar
I painted it cast coat iron DE1651 from duplicolor. Installed freeze plugs, use permatex #1 if any of you are doing this yourself .
Attached Thumbnails 854x4's 22RE Rebuild Thread-picture-108.jpg   854x4's 22RE Rebuild Thread-picture-107.jpg   854x4's 22RE Rebuild Thread-picture-109.jpg
Old Jul 5, 2009 | 09:45 PM
  #30
854x4's Avatar
Got the crank,pistons,rear seal, timing cover, and oil pump installed.
Attached Thumbnails 854x4's 22RE Rebuild Thread-picture-110.jpg   854x4's 22RE Rebuild Thread-picture-111.jpg   854x4's 22RE Rebuild Thread-picture-113.jpg
Old Jul 5, 2009 | 09:47 PM
  #31
854x4's Avatar
Timing cover pictures. Oil pans next.
Attached Thumbnails 854x4's 22RE Rebuild Thread-picture-112.jpg   854x4's 22RE Rebuild Thread-picture-114.jpg
Old Jul 6, 2009 | 12:22 PM
  #32
a lot of these pics look all too familiar
good job man; looking really good so far!
Old Jul 8, 2009 | 10:24 PM
  #33
854x4's Avatar
More pictures. I got the oil pan,waterpump, and some brackets put on. Took the head down to the machine shop and I should get it back next week. The plan was to get a engnbldr head but my old head looks in good enough shape.
Attached Thumbnails 854x4's 22RE Rebuild Thread-picture-122.jpg   854x4's 22RE Rebuild Thread-picture-123.jpg   854x4's 22RE Rebuild Thread-picture-124.jpg
Old Jul 8, 2009 | 11:28 PM
  #34
RMP8080's Avatar
pretty clean motor, do bad it's going into a vehicle that you have to use off-road
Old Jul 9, 2009 | 08:29 PM
  #35
daaaang! look'n nice!
dropping my motor in is postponed for a week due to getting an incorrect clutch from MC so you have time to catch up to me
Old Jul 14, 2009 | 08:20 PM
  #36
854x4's Avatar
Got the head back form the machine shop. Hot tanked , valve job, surfaced, and number three spark plug helicoiled all for $170
Attached Thumbnails 854x4's 22RE Rebuild Thread-picture-128.jpg   854x4's 22RE Rebuild Thread-picture-129.jpg
Old Jul 14, 2009 | 08:22 PM
  #37
854x4's Avatar
Heres the head on the block with 268 cam installed.
Attached Thumbnails 854x4's 22RE Rebuild Thread-picture-130.jpg   854x4's 22RE Rebuild Thread-picture-131.jpg   854x4's 22RE Rebuild Thread-picture-132.jpg
Old Jul 14, 2009 | 08:25 PM
  #38
we could swapt a few brackets and my motor would be completely RED, lol
looking good man!
anyone else notice there's a lot of 22re rebuild threads going on right now, lol
Old Jul 14, 2009 | 08:26 PM
  #39
854x4's Avatar
Heres some more pictures with some brackets and misc installed. Just need to adjust valve lash. The last picture is the lower intake after I took the gasket off using a bench grinder with a brass wire wheel. Yes its still flat I checked it with a straight edge.
Attached Thumbnails 854x4's 22RE Rebuild Thread-picture-133.jpg   854x4's 22RE Rebuild Thread-picture-134.jpg   854x4's 22RE Rebuild Thread-picture-135.jpg
Old Jul 15, 2009 | 07:02 PM
  #40
854x4's Avatar
looking good man!
I dont know that might give you too much red,lol
I have noticed that there have been some rebuild threads going on.
I got my bottom intake cleaned and painted today, I even buffed the inside of the runners, now it looks like new on the inside no carbon or oil. I will post pictures tonight.
