85 4 runner- 3-5 lbs fuel pressure? WTF?
Old May 3, 2008 | 09:20 PM
85ghettorunner's Avatar
85 4 runner, 22r fuel injected. My truck started stalling at idle. It runs fine while on the gas and i can keep it idling at 1k rpms with a little push on the pedal. When NO pressure is put on the pedal the truck drops to 500rpms and then stalls.
I hooked up a fuel pressure tester between the fuel inlet line and FPR. It reads at MOST 5lbs and drops to zero with any throttle.
I drained the gas tank and replaced the fuel filter(pain in the ass) and STILL get 3 to 5lbs at MOST. Is this normal or do i have a bad fuel pump? Ideas?
thanks in advance.
Old May 3, 2008 | 09:27 PM
TOYOTA 1's Avatar
i think your supposed to have around 30lbs with efi! sounds like your pump is taking a poo!
Old May 3, 2008 | 10:02 PM
Noltz's Avatar
What's the pressure at when you're spinning 1000rpm? If it's still 3-5lbs, I suspect your gauge is actually broken and you're not looking at a fuel supply issue but more likely an Idle-Air control valve/motor (very common).
Old May 4, 2008 | 03:33 AM
blueyoda's Avatar
small things first. check the filter, it may be clogged, but if it were truely a delivery problem it would die when you give it throtle, and idle alright as it needs less preasure.
Old May 4, 2008 | 05:10 AM
Flash319's Avatar
The more you rev it the more gas you need. The pump in the tank runs the same reguardless or engine load. If you can rev the engine up then your have enough pressure. Sounds like something else because the pump will work or it won't usually.
Old May 4, 2008 | 08:03 AM
Yoda's Avatar
The air flow meter (AFM) has contacts in it for the fuel pump. Too little air flow through the meter and the pump contacts open, shutting off the fuel pump. Make sure you have no air leaks between the AFM and the throttle body.
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
v_man
Jul 23, 2015 04:01 PM
Poppie51
Jul 16, 2015 06:16 PM
