5vz swap transmission question
hey yotafam,
Considering a 5vz swap on my 90 2wd at v6 because its a dawg and gets 180 miles to the tank. I read in some swap threads that the 5vz harness has a plug for the trans that my current one wont have. Should I swap the newer trans in to avoid this issue? Does the newer trans have the same gearing or is it different?
thanks in advance
shem
thanks in advance
shem
