4x4 quit help?
Old Nov 26, 2009 | 01:02 PM
82odyota's Avatar
4x4 quit help?
my buddies 90 four wheel drive quit working it will go into gear in the case but it no longer has four wheel drive any common problems with these trucks im not very up to date on much thast not first gen so any ideas will help thanks
Old Nov 26, 2009 | 01:31 PM
peow130's Avatar
Well uhhh.
Hubs locked?
Driveline in?
there could be a ton of things up..
Old Nov 26, 2009 | 01:58 PM
bain's Avatar
id say make sure both hubs are locked
Old Nov 26, 2009 | 09:59 PM
abecedarian's Avatar
ADD? Getting vacuum to the servo so the sleeve on the front differential engages?
Old Nov 26, 2009 | 11:49 PM
livetoride88's Avatar
my 91 did the samw thing the easy fix is to install locking hubs then u can run a longer bolt into the detent hole on the bottom of the add shifter and the bolt will hold it in the lock or 4x4 position the use the locking hubs to engage or disengage the front axle
skebe22RTE
Jul 31, 2015 02:03 PM
pyramid
Jul 29, 2015 06:53 AM
Yota.Jay
Jul 26, 2015 05:50 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
Nickdigg
Jul 7, 2015 06:04 AM
