4runner trim piece behind doors
How does the trim piece come off? Clips...? or from inside the truck with screws? I don't want to break it.
It's the black plastic piece behind the doors, that says 4runner on it. 5"x15".
thanks
thanks
I believe they are 'captured' trim, meaning there is a clip in the body that holds the piece on. They should pop off with some moderate pressure. But don't quote me on that. I've never taken mine off.
I took some off a while back, I think you push up first then pull out or out first then slide them up, I've got some in a box somewhere, I'd post a pic of the back and you could see how they come off but I don't know which box they're in.
You have to break the clips that hold it on. I've heard that some versions allowed you to flex it in such a way as to allow the louver to pop off, but you'll still need to remove the old clips by breaking them to re-install it.
The easiest way to remove it without damage is the use a putty knife and a hammer to shear the clips. But you have to know where the clips are to cut them.
BTW: those clips are a dealer item and they are $4.00 each.
The clips have a funky square head on them that fit into slots on the back of the louver panels. You might be able to find some generic body clips that will work, but I didn't have any luck.
BTW, you don't pry with the putty knife; you use it to bust the clips which is why you also need a hammer. If you try to pry the louver off, the slots on the back of the louver will break before the clips do. You'll need to slide the top back to reach the clips towards the rear.
BTW2: There are actually two style of clips required. IIRC, the ones on the bottom are a different part number.
Jun 1, 2021 01:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
