40" tires on 2nd gen!
Old Nov 14, 2005 | 06:41 PM
  #41
4rnr's Avatar
ITS GREAT TO SEE SOMEONE THINKING OUTSIDE THE BOX.
AWESOOOMME - <CARTMAN>
OH AND BY THE WAY YOU SHOULDNT HAVE TOLD US WHERE YOU LIVE BC IM COMIN OVER TO STEAL YOUR $ TREE
Old Nov 14, 2005 | 06:43 PM
  #42
freshman's Avatar
Nice rig man!
keep us posted on your trail rides.
  #43
4Mogger's Avatar
[QUOTE=Silver_Truck]Lookin at around 3k...the guy with that 4runner claims he put almost 20k into it.
QUOTE]
The axles were about 6K a piece. Started at 3600$ for factory remanufactured 404s with disc brake and pinion conversions. I had them narrowed 7.5 inches to center the rear pinion (offset 7.5 inches to the right in a Mog) and the front to put the pinion where I wanted so it can flex between the oil pan and frame rail on the driver's side. Then the custom CTIS unions and bolts had to be machined and installed-- this added about 2 grand to the total-- then shipping from BC Canada to St. Louis.
The wheels are awesome but were stupid expensive and the only thing I would probably do differently but they are very cool. 2 pcs. with rubber internal double beadlocks so I can mount my own tires with nothing but a torque wrench, an extension and a socket. After years of tire shops screwing up my wheels I can finally say no more of that crap.
And the wheels are designed to be used for CTIS so all of the Hummer bits and the Mercedes parts blend together beautifully.
Old Nov 14, 2005 | 06:44 PM
  #44
4Mogger's Avatar
Originally Posted by ravencr
Can you explain this further? Will it automatically adjust to keep the body level when off-roading? I mean, will it automatically detect the body beginning to lean and automatically pump up the down side to compensate
Chris
In short, yes. And in very short order, less than 1 second.
Old Nov 14, 2005 | 06:47 PM
  #45
4Mogger's Avatar
The system has four ride height sensors mounted on the upper links that constantly detect any change and instantly correct
Old Nov 14, 2005 | 06:49 PM
  #46
4Mogger's Avatar
But the driver can manually override the system too but once you hit 20 mph (or other preset speed) the system automatically returns to street mode and rises or lowers to designed ride height.
Old Nov 14, 2005 | 06:50 PM
  #47
4Mogger's Avatar
More on the suspension system here:
http://www.offroadonly.com/products/...irock2-2.shtml
Old Nov 14, 2005 | 07:00 PM
  #48
ravencr's Avatar
So, if you are riding along and all of a sudden the left side drops off into a ditch causing the body to roll to the left, the bags on the left side will automatically pump up really quick to level the body back out, automatically? If that's true, that's a badass system definitely worth the money in my opinion.
Do they make a partial system, maybe possibly only for the rear of a vehicle, for example?
Chris
Old Nov 14, 2005 | 07:48 PM
  #49
4Mogger's Avatar
Chris
Yes it should work just as you suggested in your example. The airbags move from 7" compressed to 21" extended-- this takes a while in demo modes (3 or 4 seconds) since the compressor is maxed out but on the trail with the air tank at 125 psi and ready to go it should happen very quickly.
Also manually over ride. Say I get hi centered on the cross member skidplate, just go all up which also decreases my wheelbase and would lift me right off. Or need better approach or departure angle--just tilt the front up/down or back up or down, whatever.
I do not think it would be adaptable for the rear only for computer control, but manual control would be easy to set up.
Old Nov 14, 2005 | 07:52 PM
  #50
ravencr's Avatar
Are you planning to wheel it when you come and pick it up, because I live in Severance, CO and would love to see this system in action?
Chris
Old Nov 14, 2005 | 07:56 PM
  #51
4Mogger's Avatar
Chris
Yes I do plan to. Would be happy to give you a call.
Old Nov 14, 2005 | 07:58 PM
  #52
4Mogger's Avatar
Actually, I will be in Windsor as well, that close enough for ya!?
Old Nov 14, 2005 | 08:12 PM
  #53
BruceTS's Avatar
4Mogger, I've been reading about your build-up for quite some time now on PBB.
Good work so far.......
Old Nov 14, 2005 | 08:18 PM
  #54
colsoncj's Avatar
I'm going to be in Detriot Jan to Mar and would love a wheelin partner... that rig is an inspiration, excellent job!
Old Nov 14, 2005 | 08:22 PM
  #55
4Mogger's Avatar
Thanks. I got bored over there and dropped by here to see what you all were up to and then find pics of my rig that I didn't take so that got my attention.
Thanks for the interest. shouldn't be long now.
Old Nov 14, 2005 | 08:26 PM
  #56
4Mogger's Avatar
I have a new Tundra and trailer so I will be ready! Anything under a couple hundred miles I will drive it.
Old Nov 15, 2005 | 02:59 AM
  #57
99_Runner's Avatar
That is an awesome looking rig. Props for doing something totally unique and custom.
Old Nov 15, 2005 | 03:14 AM
  #58
Cebby's Avatar
x2
Good to see someone taking a full bodied rig to it's limit. I think the "expedition type" vehicle really appeals to much of the membership here.
Old Nov 15, 2005 | 06:17 AM
  #59
nrgetic99's Avatar
So where are the Hella's now
I will never belong at Pirate for that reason.... you do something no one has ever done and engineer the whole thing clean and they don't like the Hellas.
Killed me.
As an engineer, I can say that is a truly awesome project...and if you are anything like me, the engineering challenge gives as much satisfaction as the end result, if not more.
More power to ya.... I say again, inspirational !!!
David
Old Nov 15, 2005 | 07:19 AM
  #60
colsoncj's Avatar
We've got a few places to wheel around the Flint area, bout an hour north of detroit.. but im always looking for new places if you know of any
