3VZE Woes Revisited
Old Mar 9, 2007 | 04:24 AM
4runner_Jeff's Avatar
3VZE Woes Revisited
https://www.yotatech.com/forums/show...ight=3vze+woes
Note my original posting above.
Well the results of my dry and wet compression test are back and I am going to need a new engine.
Dry Compression Test Wet Compression Test
Front of Engine Front of engine
85 125 95 140
110 10 125 35
0 70 0 80
That puts me in the market for a used 3VZE. I don't see much point in trying to rebuild a 3VZE with 274,000 miles on it. If you know of a good one in the Northeast, please contact me.
jeff_a_miller@hotmail.com
Old Mar 9, 2007 | 04:54 AM
littlerunner's Avatar
orientengine.com
Front of Engine
85 125
110 10
0 70
Front of engine
95 140
125 35
0 80
Old Mar 9, 2007 | 05:02 AM
Bumpin' Yota's Avatar
the cheapest rebuilt longblock Ive seen is 1800+500 core charge. You sure having the block punched, honed, decked, hot dipped, and the crank surfaces worked on and the replacing all internals isn't cheaper? (3vzfe uses a forged crank that will drop right into our 3vze from what ive been told)
I dont know as Ive not been down this road...yet. *gulp*
Old Mar 9, 2007 | 05:33 AM
I was hoping for something of the salvage yard variety, dumping a large amount of $$ into an engine is not in the cards, however, neither is selling the 4runner for a couple hundred dolllars.
Old Mar 9, 2007 | 06:56 AM
TNRabbit's Avatar
ZERO compression?!? Wow....never seen that before. You must have a valve stuck open.
Old Mar 9, 2007 | 07:38 AM
UncleBob's Avatar
How do you know you need a new engine and not just a head?
Old Mar 9, 2007 | 08:05 AM
mt_goat's Avatar
Yeah those are the worst compression numbers I've ever seen.
Old Mar 9, 2007 | 09:32 AM
faubrunner64's Avatar
yeah ive enevr seen 0 but i have had under 50 in 3 cylinders before, but that is due to a little company called doa that screwd me over 3 times.
Old Mar 9, 2007 | 11:26 AM
Yep, they aren't good.
The mechanic who did the compression tests told me that the double zero was likely caused by a burned piston. I don't know if he considered a stuck valve or not.
Old Mar 9, 2007 | 12:04 PM
MonsterMaxx's Avatar
Screwed by DOA. We ought to form a help group or something.
I got boned by him too. What a crook.
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
