3vze top end rebuild...now wont start!! Code 14
#30
thanks a lot bone collector, I will give this a shot first thing tomorrow when im checking out my sticky clutch pedal. Gets stuck halfway. 2 Steps forward 1 step back the story of my life. Lol Thanks again
#33
Just figured out the timing light thing...new problem im thinking my timing is outta whack now cause my ignition time will only make it to 5 degrees btdc? Pretty sure this indicates the timing is outta whack right? anyone want to chime in...be easy on me!
#35
I had this same exact issue with my brand new, correctly installed distributor. I thought it was off a tooth and so I placed it back one, and then it was well above the 15 degree mark and the engine started pinging. I put the old one on which I had incorrectly diagnosed broken, and it fit just right in the range.
This doesn't mean it can't be off by a tooth. Regardless, since you're are down at 5 deg (mine reach the limit at 10) moving it back a tooth may give you the correct range.
#38
Thanks bone collector!!
UPDATE: I replaced the master cylinder and slave cylinder because my clutch was getting stuck to the floor. I noticed that fluid had leaked out of the master cylinder onto the carpet . Now this ones leaking, admittedly i did buy a master from Autozone lol whats the likelihood that its the part and something else isnt messing up with the clutch. Seems like a simple system so I dont know what the deal is...
I havent done much research on this yet so if its out there my bad.
#39
If your still have trouble seeing your timing marks or they seem out side of the adjustment range I would recommend checking the crank pulley itself. The pulley has a rubber damper sandwiched between the inner metal portion and the outer belt portion. The rubber rots and the outer portion will move which means the timing marks move with it.
zd92655
Mar 6, 2022 12:58 PM
stagger_lee
Mar 29, 2016 06:27 PM
jmc88runner
Jun 18, 2015 03:39 PM
infinityisfive
Jun 16, 2015 06:51 PM
