3VZE timing belt experience and thanks
First of all thanks to all members who posted their tips, tricks, and write-ups on doing this maintenance. I read many threads prior to starting work and it definitely helped. My truck is a 1992 V6 5 speed 4X4.
I would like to encourage anyone who is thinking of doing this to go for it, it is time consuming the first time through, but not technically difficult. I am not a pro so if I can do it anyone can. I spent probably 10 hours total, but I worked slowly and had a few unforseen delays. Next time I could probably do it in 5 hours or less. I replaced the timing belt, both idler pulleys, water pump, thermostat, cam and crank seals, radiator hoses, and drive belts.
The only problems I had was my radiator bracket was broken, so I had to go get that soldered back on, and I needed to go rent a harmonic balancer puller to get the crank pulley off. Everything else was straightforward.
Again, thanks to the YotaTech community for their help and support.
Dave
Dave
Yea isnt this site amazing?! On top of all the sweet write ups there is alot of great advice.
Not only is this place great for anything toyota related but there is a great group of people here.
Welcome! You will enjoy it here.
skoti89
Jul 6, 2015 07:45 PM
