3vze rough idle, no power, no power brakes
Old Mar 2, 2016 | 09:32 AM
Darrel Forney's Avatar
Unhappy 3vze rough idle, no power, no power brakes
Help!
I have a 91 4runner, 3vze, auto, 78k miles(thats right, probably the lowest mileage 2nd gen 4runner in the states)
3 days ago the starter went out, before hand it was running perfect, has always idled a little high (1500rpm) but was solid.
When I looked to replace the starter the bottom bolt had fallen out and the top bolt was halfway out. I replaced the bolts and ever since its had a rough Idle, only down to 1200 rpm at idle and 600 rpm in gear. and now there is little to no power assist with the brakes.
things I've done
Compression check, 140psi on all cylinders
Fuel Pressure 40psi, no worries there
New plugs and wires checked each, has spark
swapped VAFM with known good one, no change
cat rusted out long ago, no restriction there
been examining vaccuum hoses and dont see any issues,
I figure at this point it is either a vaccuum leak I haven't found (will be smoke testing system shortly) or the tps, but the lack of brakes is making me lean toward vaccuum leak.
sorry for the long story, any advice would be great
Thanks
Old Mar 2, 2016 | 09:47 AM
92ehatch's Avatar
Could be a bad booster or booster check valve.
The check valve is easy.
Take it off, blow through it, it should blow one way but not the other.
Your idle and performance issues could be due to that system as its probably a vacuum leak issue.
Old Mar 2, 2016 | 04:33 PM
Thumbs up Found it!
Performed a smoke test to find vacuum leak with my improvised smoke machine of a paint can with a air hose connect on one end and a vacuum hose on the other, some burlap on the can smokes a lot when set on fire and piped into the system, found smoke coming from under the passenger side of the intake manifold, removed upper manifold and found the erg tube and cracked halfway up the pipe
vikecowboy
Mar 9, 2016 10:14 AM
vickie89
3.4 Swaps
Jan 9, 2016 06:33 PM
AZSPEED
Dec 22, 2015 06:17 PM
Brandon13
Dec 11, 2015 10:31 AM
PureTacoma_Tundra
PureTacoma_Tundra
Dec 8, 2015 09:20 AM
