My 94 Runner (3VZE) engine is out and completely torn apart. I was suprised to find that most gaskets were sealant rather than prefab gaskets. Is this what the factory uses, or should I assume someone else has broken down the engine? Does anyone have a recommendation on using gasket sets or sealant? If so, what kind and where do you get it/them from?
i'd get a kit from rock gasket, use all the rubber gaskets but on the oil pan use RTV. don't use any of the cork gaskets because they're crap
I would recomment the original Toyota gasket kit. Includes pretty much everything including the headgaskets, gaskets for the timing covers, injectors and for the fuel pipes. I even have some gaskets I have no idea where to put. Use RTV where Toyota recommends.
check out e-bay, I got a complete top end kit brand new with new head bolts for just over 83.00 shipped compared to others who wanted over 2 - 300.00... 3.0 V6 3VZE 1989 4x4 pickup
Quote:
With headbolts? Watch out, you might be getting what you pay for there.Originally Posted by rgrounded
