3vze re assembly parts list
Old Mar 24, 2006 | 07:57 PM
Phate's Avatar
Question 3vze re assembly parts list
Ok so heres the story, had the water bypass pipe blow on my 3vze so I had to tear off the intake plenum, intake manafold ect. so now that i have it apart and replaced the waterbypass i need to put it back togather again heres the list
Throttle Body Gasket
Plenum Gasket
Intake Manafold Gasket
Cold Start Injector Gasket
Fuel Rail Crush Washers, i didnt take the fuel rail completely out just unbolted the front half, so i think i only need 4.
Injector, o rings? (may buy new injectors or get mine refurbed any opinions?)
Heater hoses
Vaccume lines (i have thought about redoing these in silicone, opinions?)
Valve Cover Gasket(didnt take them off yet but figure hey while im here)
Valve cover bolts
PCV
New Belts (may as well)
my questions are,
can any one think of any parts im missing? im sure there are some. and on the gaskets should i use any thing to help them stick in place?
Old Mar 25, 2006 | 02:22 AM
YotaJunky's Avatar
You'll need some RTV gasket maker for the 1/2 moon areas on the valve covers before you seat the valve cover gaskets.
Troy
Old Mar 25, 2006 | 07:59 AM
Radyota's Avatar
While you're in there you might want to check/reshim the valve clearances as preventative maintenance. Replace the knock sensor wire as well, as those are touchy and will set off the check engine light and decrease your gas mileage if it fails. It's only $12 - $14 at the dealership.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
smiley52
Jul 11, 2015 05:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
