3VZE overheats, not thermostat, no heat
Old 11-23-2011, 06:49 AM
TNRabbit's Avatar
Originally Posted by Marc
You would think so but AF seems to flow freely out of the lower rad hose when I drained it.
That's not the important part; if there is sufficient crap built up on the inside of the passages themselves, the thermal efficiency of the radiator goes out the window. You must be able to TRANSFER the heat; flow is secondary.
Old 11-23-2011, 07:19 AM
Marc's Avatar
Ok, but when it overheated I was going 55mph at 0 degrees F.
That's a lot of cold air going through the rad and by the engine.
Not arguing with you just throwing stuff out there.
Believe me, I'd be thrilled if it was the rad.
Old 11-23-2011, 10:21 AM
ZUK
ZUK's Avatar
Then you should start being thrilled
Old 11-23-2011, 12:42 PM
Marc's Avatar
Well, here's hoping!
Old 11-23-2011, 06:17 PM
  #25
James Woods's Avatar
Have you checked the fan clutch? Can you hear it in the morning? Will it suck a piece of paper to the grill when running?
Old 11-23-2011, 07:50 PM
  #26
BMcEL's Avatar
Something tells me it has nothing to do with the fan...
Old 12-02-2011, 01:52 PM
  #27
ZUK
ZUK's Avatar
correct
Old 12-02-2011, 02:08 PM
  #28
chwkrx7's Avatar
Feel the rad after driving it. If it has cold spots, it's definitely plugged.
Make SURE the water pump is pumping. Impeller could have separated from the shaft, I'm a mechanic and I've seen it happen several times on several vehicles.
I know you don't think the rad cap is a problem, but get it tested to make sure it HOLDS at 13 PSI or better.
Old 12-03-2011, 04:31 AM
  #29
Thor95's Avatar
What finally fixed my overheating issue after replacing all the cheap, easy stuff was a new radiator.
Old 12-06-2011, 08:19 AM
  #30
Marc's Avatar
** update ** Talked to shop.
They think the water pump is shot.
Rad might be shot.
Decided not to fix it now but I'll put my 91 back on the road.
I'll update this post in the spring after I tear it apart.
thanks for all the help
Old 03-21-2012, 02:45 PM
  #31
Marc's Avatar
** another update **
Finally warm enough to work on it.
Water pump was seized.
That explains why it wasn't moving water and overheating.
Thanks for the ideas.
MadMax48
03-03-2020 10:33 AM
LotOMiles
09-14-2015 11:45 PM
noahstancik
09-10-2015 10:47 AM
--Oz--
09-06-2015 01:06 AM
Quick Reply: 3VZE overheats, not thermostat, no heat
