3vze ignition nightmare!
Old Apr 28, 2010 | 08:48 PM
  #41
tantivity75555's Avatar
Wiring Harness
Does any one know if this is the wiring harness right behind the timing belt cover, and under the front of the plenum? And does the plenum have to be removed to replace the wires?
Old Jan 15, 2011 | 05:32 PM
  #42
Yota2k55's Avatar
Could this be the wiring that is attatched on the front clip behind the grill?
Old Feb 24, 2011 | 01:01 AM
  #43
kinkcycle128's Avatar
aany chance you guys could dump this way way down on step by step it would be very useful and detailed very appreciated, like what settings do i put my voltmeter at?, sorry im still learning this wiring stuff
Old Sep 17, 2011 | 09:29 PM
  #44
PhilR's Avatar
I'd also like more details, pictures and explanations.
My 1993 3VZE starts more quickly when very cold, it takes longer to start in summer but that doesn't bother me.
The problems I have are relatively low power at lower RPM and some pinging at around 70-75 mph even with 91 octane fuel. The ignition timing is supposed to be ok, I tried with a bit more advance with no noticeable increase in power but more pinging, and with less advance and I couldn't get faster than 65 MPH with the pedal to the floor on the overdrive (so that solved the pinging problem above 70!)...
There are no codes but there was once a distributor code that was erased at the dealer and it didn't get back on my next visit. Fuel pressure was supposed to be ok too.
My truck has stock 31" tires, manual transmission and 4.56 gears. I got this truck at 124,000 miles and it did have this problem already and now it has 165,000 miles and I still haven't figured what was causing this problem. The timing belt was replaced at the dealer at 130,000 but there was no improvement (and the belt was checked at 155,000 miles for the alignment of the cam pulleys and it was still correct)
It's quite fuel efficient as I can do more than 335 miles with a tank of fuel (slightly better than my 22RE with 4.10 gears!) but it doesn't feel more powerful than my 22RE either!
Old Jun 19, 2012 | 07:30 AM
  #45
Colombo's Avatar
Bump
Frozen Wave...
Do you have any more info on this? Your info may be the answer to my own nightmares!
Thanks!
Old Sep 5, 2012 | 09:08 AM
  #46
Toreador's Avatar
So, no?
No pics?
No answers?
Nobody cares anymore?
Old Sep 5, 2012 | 10:29 AM
  #47
iselloil's Avatar
Is he talking about the harness that runs across the front of the engine,behind the timing belt?
MadMax48
Mar 3, 2020 10:33 AM
tazman1972
11
Sep 28, 2015 10:32 PM
87runner_
Sep 19, 2015 03:28 AM
JHalcyonM
Sep 14, 2015 01:10 AM
