3VZE coolant leak - pass side
Old Jan 13, 2016 | 11:24 AM
az4x4runner's Avatar
I am pretty familiar with this engine, and I've searched and searched, but can't seem to pinpoint this leak without tearing the AC compressor and everything around it out.
I have a leak somewhere on the passenger side above the AC compressor. Coolant actually drips off the compressor and on to steering linkage.
I can see the freeze plugs through the wheel well, they're dry.
It's just a little trickle, mostly after cold start and quickly shut off, driving me nuts for months now, but no visibility behind the compressor. Any ideas?
Old Jan 13, 2016 | 12:00 PM
I just pulled the tire off so I could really get in there and look, all dry, all round front freeze plug, dry. I can see where the hydraulic timing tensioner bolts up, dry. Wtf...
Old Jan 13, 2016 | 12:39 PM
MudHippy's Avatar
And it's not leaking from the obvious spot right above the AC compressor? As in the coolant drain plug for the RH side of the block.
Old Jan 13, 2016 | 12:40 PM
Correct. The drain plug is behind motor mount, between the two freeze plugs, right?
Old Jan 13, 2016 | 12:42 PM
Actually the drain plug I see, if it is indeed a drain plug, is very close to the front freeze plug. Got a pic of the right side of a 3VZE?
Old Jan 13, 2016 | 12:49 PM
MudHippy's Avatar
That's the one. 14mm hex head brass plug.
EDIT: I found a good pic. It's a 5VZ-FE .But it's in the same location as a 3VZ-E.
LucasF249
Feb 23, 2016 12:12 PM
-City Slicker
Jan 5, 2016 06:54 AM
80seriesftw
Nov 22, 2015 07:50 PM
Mattluke1
Nov 2, 2015 07:08 PM
anndel
Oct 24, 2015 11:34 PM
