3VZE code 24 Help!
3VZE code 24 Help!
91 3vz-e recently gave the code 24 so i replaced the air flow sensor (no engine light ever came on, just noticed engine losing power at ~3200 rpm).
i disconnected the battery to clear the code but the problem persists and it is flashing the "normal" code.
how long does it take to create a new code? i was sure the engine operating temp was hot enough.
could this be a fuel pressure problem? tps sensor? ect sensor? o2?
plugs are new but wires haven't been changed in about 3 years.
help!
help!
ok, so just finished new plugs and wires and the problem is still there. i noticed a small crack on the air tube lip that connects to the throttle body.
could this small crack cause this?
and it still wont give a code after a 10 minute warm up. any advice on troubleshooting without codes?
LotOMiles
Sep 14, 2015 11:45 PM
EatChipsNow
Sep 9, 2015 01:25 AM
