3rd member removal help
I have everything off....axles, drive shaft, all bolts around 3rd.....seems like it should come loose with some wacks of a BFH....no go...tried to pry with a big screw drivers...doesn't budge....tried a few wacks with a chisel....nothing.
should I just keep trying with the chisel?
darn ET...wish I had read ur post earlier....I basically wacked it a BFH and wiggled it out.
On initial inspection, the ring looked good...then I put a light down into the pinion and it was missing a few teeth...ugh.
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
FS[PacNorWest]: 1982 Toyota Long Bed Trailer
58rennur4
Aug 4, 2015 08:49 AM
