36/15.5 tires on 4-5inch lift
Old 10-25-2009, 01:13 PM
Junkers88's Avatar
Originally Posted by JamesD
I'm running 35x12.5x15 on stock 7" rims and the rub a little.
Do you have any issues running a 12.5" tire on a 7" wheel?
Old 10-25-2009, 01:39 PM
JamesD's Avatar
Zero issues other than what I mentioned above. It barely rubs the upper control arm but that is if you are flexing the sidewall or lowering the tie pressure. The original owner of the truck used 1/4" spacers in the front so it would not rub at all. It is safe and I have done it before with thousands of miles on the street.
James
Old 10-25-2009, 01:49 PM
Junkers88's Avatar
Zero issues other than what I mentioned above. It barely rubs the outer tie rod end but that is if you are flexing the sidewall or lowering the tie pressure. The original owner of the truck used 1/4" spacers in the front so it would not rub at all. It is safe and I have done it before with thousands of miles on the street.
James
Thanks! I'm looking for new tires and the one's I want in 33" only come in 12.5" width and I don't want to buy wheels if I can help it.
Old 10-25-2009, 04:39 PM
abecedarian's Avatar
The main issues with wheel spacers are:
a) pushing the rim out from the hub, particularly on the steering axles, puts strain on wheel bearings.
b) pushing the rim outward on the steering axles moves the contact patch outward from the 'imaginary' line drawn through the upper and lower ball joints (steering axis inclination). When that happens, it makes the front wheels' steering more susceptible to bumps, potholes, etc. in the road.
Old 10-25-2009, 04:48 PM
  #25
g_cali's Avatar
Might i suggest 35x12.5's?
Old 10-26-2009, 09:13 PM
  #26
limon32's Avatar
But thats so regular!
I really want to see these big tires he's gonna mount up!
Old 10-26-2009, 10:03 PM
  #27
anthony1's Avatar
You plan to re-gear too right?....both axles?
Old 10-27-2009, 06:25 AM
  #28
JShaffer0525's Avatar
where DID I put my Picard pic or maybe the dump-truck full of fail?
Old 10-27-2009, 07:51 AM
  #29
JamesD's Avatar
James
I had to correct myself. I thought it was the outer tie rod but it is the lip of the upper control arm that is rubbing. You can either grind the lip or just get the $20 spacers from Advance Auto.
James
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
nickbeauregard
12
08-07-2015 06:04 AM
Luvmeye22re
08-04-2015 03:53 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: 36/15.5 tires on 4-5inch lift
