#3 bypass re-route
#3 bypass re-route
I have a 1990 4runner that has a clogged by-pass pipe not the #3 hose but the pipe once it leaves the hose. Has anyone re-routed the #3 hose over to the #5 by-pass hose? I want to do this due to the cost of replacing the existing hard pipe that is under the intake manifold, etc. Thanks
Wouldn't clearing the pipe be easier than building a "Y" and blocking off #3's down tube? I mean sure you gotta take of a bunch of stuff to get to it to remove it but seems kinda wrong to go messing with the cooling system on those.
*Shrug* run with the heater valve open and think about it.
It's off the engine?
Fill the tube with CLR or vinegar and let it soak it's way thru.
For a "tool" I'd go with piano wire, a soft copper coat hanger, and/or some light duty multistrand cable chucked up in a hand drill. (Like bicycle brake/shifter cable). Just have to use the right rotation so the cable doesn't try to unwind, think plumbers snake.
Worse case you could cut it off and put a flare nut on the pipe section you have to keep, and put a 8-12" solid brake line on there. Not sure how that'd work out depends how tight the space.
Good luck, stick with it and you'll get it fixed!
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
zz_denis
Sep 6, 2015 03:43 PM
