3" bj spacer lift only 1.75"?...
Old Mar 5, 2016 | 12:25 PM
Dustin Egle's Avatar
Just got my bj spacer lift kit in, 3" front 2" block for the rear. The blocked measured 2 in but the bj spacers are only 1 3/4"?...I take it you have to crank the Tbars to get the 3?..
Old Mar 5, 2016 | 12:51 PM
TransAmBandit's Avatar
Where did you order the spacers from? Usually they are 1.5 inches tall and you adjust the bars to get the other 1.5. I bought a set used and the spacer turned out to be 1.75 tall.
4Crawler sells his in 1.5
Old Mar 5, 2016 | 01:00 PM
http://m.ebay.com/itm/281820624671 got the kit off ebay, I'll read measure in a second to make sure it was 1.75. Pretty sure it was (it is 1.75 just measured)
Old Mar 7, 2016 | 09:40 AM
SacRunner's Avatar
The guys that sell those 3" kits don't tell you that you have to crank the torsion bars all the way up to their max to get the 3" of lift....DON'T DO THAT.
Enjoy the 1.75" that you'll get and be done with it, or grab a small body lift if you really need the extra lift.
Old Mar 7, 2016 | 12:13 PM
Gevo's Avatar
yeah, as SacRunner says.. don't tighten the torsion bars so far up. Also, the BJ spacers and the torsion bar do two completely different things to get the lift. Pushing over 1.5-inch lift requires other modifications which you should look into or else you will ruin various other components.
Old Mar 7, 2016 | 03:34 PM
wolfrunner's Avatar
Yeah I agree with them both. Be cautious with how much you crank those suckers up. I do alignments on lifted trucks all the time and cranked bars will just throw everything out.
TheEastBeaster
Mar 7, 2016 06:11 AM
Questions
Mar 5, 2016 04:05 PM
incendui
11
Mar 2, 2016 10:13 AM
Dustin Egle
Feb 17, 2016 04:56 PM
