3.4L V6 to W56 Bellhousing? Does it exist?
Old Feb 1, 2007 | 06:21 PM
DeathCougar's Avatar
Does anyone make a bellhousing to bolt a 5VZE 3.4L to my W56 Transmission? I want to keep the gear drive trans, and not have to make modifications to my floor by putting in the R 151F trans. Im doing the ORS swap in my 86 4Runner soon. Its not going to be wheeled much if at all, so high strength trannys like the R151F are not an issue.
Any ideas or thoughts would be helpful. Thanks!
Old Feb 2, 2007 | 02:42 AM
fillsrunner4's Avatar
I dont think you can do that, nor would I. The W56 is alot weaker than a R series. Get an r151f or at least r150f its way stronger and will hold up to the tourqe that motor is putting out. The floor work would not be that hard especially if your gonna do that swap.
Old Feb 2, 2007 | 03:41 AM
NCSU-4runner's Avatar
anything is possible, but i highly doubt anyone else would have wanted to do that before. They made adapters to bolt a gear drive tcase to R150s already.
from marlin crawlers website
V6 Adapter Plate
Allows 4Cyl gear driven transfer case to bolt onto 1988-1995 3.0L 5speed V6 transmission replacing chain drive case.
V6 Adapter Plate Instructions
Add This Item Shopping Cart MC-14210, 30-4GT V6 Adapter Plate, $349
Rob from supracharged made his own casting to adapt 7Ms to R151/150, i'll likely be getting one someday
http://www.supracharged.com/forum/viewtopic.php?t=773
Old Feb 2, 2007 | 07:54 AM
Bill's Avatar
I agree that an R-series would be a better choise. However a W-series tranny will hold up to a 3.4 just fine.
The W-series was used behind NA 7M's putting out 200hp and 188ft-lbs(this seems low to me for an I6). The 5VZ-FE puts out 190Hp and 220ft-lbs. So not a whole lot of difference. So I'm betting the W would hold up.
However, as I've already said the R-series would be a better choise, it is stronger and they bolt right up to the 3.4. And I've never heard of a bellhousing to go from a 6cyl motor to a 4cyl tranny.
Old Jan 22, 2011 | 09:50 AM
4wheelin86's Avatar
well this answered my question. i guess ill be putting a v6 and matching tranny in my 88 4runner. i do wonder how much modifying will need to be done to my floor board and is it difficult?
Old Jan 22, 2011 | 08:32 PM
hunter4runner's Avatar
I don't understand why you would have to modify the floor for a R151F, that makes little since
Old Jan 23, 2011 | 09:11 AM
Shifters are in different locations for different transmissions. I had to modify the floor of my 87 when I installed an R150F turbo trans.
Old Jan 23, 2011 | 09:31 AM
R151F Turbo Trans (not being a jerk just didn't want confusion)
Surely its not that bad, but I digress you will need a R-150F from behind a 3vze with and adaptor plate with gear drive trans or a R151F Tailhousing and T-case.
Old Jan 23, 2011 | 09:33 AM
Sorry yea, you are correct. I always get the two confused.
I have an R151F in my 4Runner. It is indeed a 4cyl turbo trans. Point being I did have to modify the floor slightly.
Old Jan 23, 2011 | 09:46 AM
BigBluePile's Avatar
You WERE WRONG?! NOOOOOOOOOOOOOOOOOOOOOOOOOOO...........!?
Old Jan 23, 2011 | 09:49 AM
Really in all honesty this is it :
R151F/R150F Bellhousing [You] R150F/Marlin Adaptor plate/Gear drive t-case
Otherwise know as :
Rock [You] Hardplace
Honestly R150F for ~$500 plus ~$400 for the plate = ~$900 (I included shipping and RTV and seals)
Or R151F for ~$700 = ~$700 plus better performance
I priced the trans high due to you'll need one in good condition, I assume if you don't want to mod the floor you don't want to rebuild the trans.
All R-Series trans will eventually have an issue with the bearing retainer and 1st/2nd shift fork, when the trans is put under stress!
Old Jan 23, 2011 | 04:46 PM
Shaddup and build your dual cases.
Oh wait
Old Jan 23, 2011 | 05:01 PM
2DoorRunner's Avatar
I dont know much about them, but its worth a shot.
You might be able to make an adapter plate, and adjust the clutch enough to make up for the extra length added from the adapter plate. Of advance adapters might carry a throwout bearing with a thicker profile to make up for the difference.
Just a thought
Similar to this...
http://www.advanceadapters.com/products/pn-712550/
Old Jan 23, 2011 | 05:35 PM
Oh wait
Don't you freakin SAS me boyo!!!!
Get your rear disc conversion and transfer case disc brake done...OH WAIT....
Old Mar 22, 2011 | 07:32 PM
Ksquared31's Avatar
Is my understanding correct that a transmission from a V6 will not work in a 4cyl?
What i am getting at is that i need a new transmission for my truck. I believe i have a w56-e transmission currently in the vehicle. (The truck is a 1994 4cyl 4x4) I am looking at buying this one in this ad. http://denver.craigslist.org/pts/2272237908.html
I will call the seller tomorrow for more details, but just want to know if that transmission from a v6 will go in my 4cyl.
Old Mar 23, 2011 | 12:45 AM
wyoming9's Avatar
Red face
I really don`t see the problem just take the 2 bell housings and make one.
The only important part is to make sure the over all length is correct
So that the clutch parts are at the correct distance to work.
Of course this is not something you can do under the tree on a nice day.
Is it worth the cost that is up to you . It is a option
Old Mar 23, 2011 | 05:22 AM
Ksquared31's Avatar
Thanks. According to this chart, it looks like a w56 transmission, regardless if it is a w56-a, w-56-c, or w56-e is the same unit. http://www.marlincrawler.com/tech/tr...ar-ratio-chart
They are all the same length. Do you know how many bolts there are for a bell housing to a v6 vs to the 4cyl?
Kyuss
47
Oct 9, 2014 08:27 AM
kowalski22
3.4 Swaps
Jun 8, 2014 04:32 PM
lbhsbz
3.4 Swaps
Oct 30, 2009 05:26 PM
lbhsbz
3.4 Swaps
Oct 8, 2009 07:22 AM
Flash319
Oct 19, 2007 11:16 AM
