3.0 rear cam seals
Old Nov 11, 2010 | 09:08 AM
oldblue's Avatar
3.0 rear cam seals
can the rear cam cam cover or seal be replaced without removing the camshafts? my valve covers are leaking bad, and its leaking a lot of oil from the rear cam plugs too. also, where would i be able to purchase these seals?
Old Nov 11, 2010 | 09:14 AM
oldblue's Avatar
nevermind, looks like two small bolts and the cover pops off and there's a seal behind that
Old Nov 11, 2010 | 09:56 AM
MudHippy's Avatar
One way to purchase them individually, outside of a gasket kit of some sort, would be from a dealership or an online OEM Toyota parts supplier.
My first choice in online OEM Toyota parts suppliers is 1stToyotaParts.com
The part number for those is 11188-65010.
I just looked on RockAuto.com and they have them also. They won't be OEM, but should work just as well.
FEL-PRO Part # ES72308
Camshaft rear seal plug set; Valve Cover
Old Nov 11, 2010 | 10:11 AM
vasinvictor's Avatar
You've already answered your own questions, but yes it can be replaced without pulling the camshaft. On mine, and I think as per the FSM, I used some FIPG around the seal. So if the PO or factory put some on it, you might have to some coercing.
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Coreyr384
Jul 10, 2015 11:13 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
