3.0 PCV Valve Relocation (easy/quick change)
Well I had to pull the intake manifold off to fix a coolant leak at the water distribution block today and while the intake mani was off I decided to relocate the PCV valve, so in the future I can change it without having to pull the intake mani.
I will also be adding a oil catch can in the future. Here are the pics and how I did it.
(Intake Manifold removed and the lower intake tapped off so nothing falls in.)
(what is left of the grommet that the pcv valve mounts into, this was no longer soft rubber it was rock hard.)
(New grommet much better.)
(90deg elbow will be used in the grommet then a rubber hose will relocate the PCV)
(New PCV Valve top and reducer bellow)
(all mounted and ready to go)
Hope this help it was super easy to do.
Chris
Chris
When I first installed it I did install it backwards lol you have to think about it when you put it in the line, however I did flip it around and that pic shows the correct direction.
No worries, I will be ordering a oil catch can after seeing how nasty the intake track was from the PCV and installing it with lots of pics ASAP.
Chris
Chris
i put an oil sererator in my mustang, and it kept a ton of oil out of the upper plenum
i just bought a cheap husky brand one from home depot and put some barbed fittings in it. prolly do one to my truck now that u mention it
Chris
the1998sr5
15
Jul 14, 2020 08:35 PM
