2wd Transmission Swap Question
Hi,
1989 toyota 2wd pickup, 250K on the clock, w46 transmission
Transmission is making a fair amount of noise on deceleration - not when cold (assuming the fluid is thicker then)
Looking to replace it with something else - I'm up in Canada so there aren't a pile of wrecking yards with toyota in them to choose from - there are a bunch of tacomas however... wait for it, here's the question..
Would a W59 from a 2wd tacoma mate up to my 22R - would I otherwise only need to swap the bellhousing from the W46? Anyone done this?
Or should I be looking for a W55 stateside instead?
Thanks,
-a
Thanks,
-a
No, the transmissions are not the same nor can yu just swap bellhousings.
The starters are switched on the transmissions, since the exhaust is switched on the engines.
k - thanks - up ihere n canada there aren't many pre '95 pickups around anymore in the wreckers. So I thought that if the W59 was a go, the solution would be simple enough.
I'll check some wreckers out stateside and see what I can come up with
-a
-a
I have a 5 spd out of a 82 model in my 89, the floor had to cut because the shifter sets further back. The speedometer cable had to be changed also . This might be a option if you are unable to find the correct one. I do not know what years bolt directly in ,with out modifying anything.
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
1989, 2wd, 85, 95, conversion, interchange, pickup, swap, tacoma, toyota, trans, transmission, w46, w55, w59
