2nd gen factory roof rack location dimensions
Old Jul 25, 2008 | 01:57 PM
mike92runnerSR5's Avatar
A little help please..I'm installing a factory roof rack on my 4runner that never had one this weekend. I want to avoid removing the headliner to verify the holes will avoid the roof support ribs..can someone tell me where the factory rack is locateed on their rig...the approx. dimension from the back window opening verticle to the start of the rails...and the dimension from the moon roof opening to the front of the rails should work..thanks in advance for the help..
Old Jul 25, 2008 | 02:19 PM
olharleyman's Avatar
Not sure of the exact dimentions as to where it should go but if you want I did one on mine and can find the wright up to help you with as much info as I could remember
Old Jul 25, 2008 | 02:21 PM
thanks olharley...you sent me your wright-up already...much appreciated..it will come in handy for sure..could you check on those dimensions?
Old Jul 25, 2008 | 02:25 PM
Trucks at home I am at work untill 11 pm hour drive home but I will try to get them to you asap
Old Jul 25, 2008 | 02:26 PM
hey thanks...if you can...otherwise maybe someone else will chime in..
Old Jul 25, 2008 | 02:50 PM
anotherjeff's Avatar
There is a write-up on this at:
http://www.ultimateyota.com/index.ph...6&topic=2218.0
Old Jul 25, 2008 | 02:56 PM
toyminator2000's Avatar
Just an FYI. The roof rack sizes were not all the same. Some were longer than others depending on the year of the truck.
Old Jul 25, 2008 | 03:58 PM
I'll check out that write-up thanks. The rails I have are 53 3/4" long including the end caps. The assembled width is 37 1/2". I believe this rack is from a 95'.
Old Jul 25, 2008 | 04:33 PM
Hophead's Avatar
I installed a factory rack I got from the wrecker - mine is only 36 1/2" long, off an earlier model. The holes in the factory rack are just shy of a foot apart (30cm). I put the first hole 10" from the back window frame edge and did not hit anything. I used nut-serts and stainless bolts to mount the rails. I can't speak for the longer rails, I specifically got the shorter ones as I didn't want to risk hitting any sunroof bits.
Hope it helps.
Old Jul 26, 2008 | 06:34 AM
hmmm..anyone else have the 53-3/4" rails on their 2nd gen or 92' runner with the moon roof?
Old Jul 27, 2008 | 11:45 AM
bump.......
Old Jul 27, 2008 | 03:07 PM
still looking to verify layout dimensions...I measured one on someone elses rig yesterday...7-1/4" to first fastener closest to moonroof. 8-1/4" to first fast. from back window.
Old Jul 27, 2008 | 04:11 PM
how about a little help..
icentropy
Sep 16, 2020 02:47 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
jetspeedz
Jul 13, 2015 09:32 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
Steezy96yota
Jul 6, 2015 10:00 AM
