2nd gen 4Runner rear quarter panel hack
Old Nov 14, 2010 | 07:30 PM
jbw's Avatar
jbw
Hey guys, I did a search but didn't come up with what I'm looking for (doesn't mean I didn't overlook it though), so I thought I'd post in here. Please move if I'm not posting in the right area.
I've got a 2nd gen 4Runner with typical wheel well and quarter panel rust in some spots. The worst is under/behind the big chrome bumper end caps in the rear, there isn't much metal left back there!
I'm thinking of just removing the stock bumper skin, cutting out the rusted section behind the end caps and capping it off with 20g sheet metal to the (still solid) inner fender. I'm not too concerned with looks as I plan on using bedliner on the lower 1/3rd of the quarter panels, rockers, doors and fenders once the rust repair is all done, should cover any minor imperfections.
Has anyone done this, any problems along the way or things to look out for and of course, if anyone has any pictures please share!
Old Nov 15, 2010 | 06:06 PM
RobD's Avatar
I made patch panels for mine, but I don't have any pictures, sorry.
Simply put, I made a template from cardboard, cut out the sheet metal, formed it to fit, then used panel bonding adhesive (http://solutions.3m.com/wps/portal/3...glQ4QF5QHMX1bl) and some pop rivets to hold the panel in place while the adhesive set up.
Far easier than welding, but you have to have at least an inch of good, solid, clean metal to bond to.
Old Nov 15, 2010 | 09:15 PM
jbw's Avatar
jbw
Do you have any pictures of the process or of what the rusted areas looked like before you did the repair? How is the body panel adhesive holding up, and how was it to use?
Old Nov 16, 2010 | 05:26 PM
RobD's Avatar
This is the only shot I have.
It's held up really well. Make sure both surfaces are clean and have good tooth (I used a 36 grit flap wheel), that both surfaces have the panel bonding adhesive on them, and that you clamp the panels (or rivet them) tightly, but not so tightly that it all squeezes out. The stuff I used has small glass beads in it to keep you from overdoing it. But it's still possible to overclamp and crush the beads.
Old Nov 17, 2010 | 10:37 AM
jbw's Avatar
jbw
Looks good, but I think I'm going to hack that part off completely. There's enough rust under there to make any patching a temporary solution. I'm looking at having some of these welded in, which should take care of the other rust I've got and give me a good surface to re-mount the factory tire carrier:
http://www.alfaparts.net/pics/toyota/t4r/t4r5.htm
Old Nov 17, 2010 | 10:41 AM
jbw's Avatar
jbw
This is what I'm dealing with, typical wheelwell rust in the back quarter panels. What you can't see is that it's pretty much all swiss cheese behind the chrome bumper cap. Sorry about the photo, it came with a bunch of really ugly stickers and a roof rack I took off immediately after purchasing a few months ago:
Old Nov 17, 2010 | 11:29 AM
cootees's Avatar
That only goes to the bumper line. If most of the rust that you want to eliminate is behind the bumper then it isn't going to do much for you.
Old Nov 17, 2010 | 04:29 PM
slacker's Avatar
if you can wait ? ..
We http://www.toyotafiberglass.com are building some fiberglass replacements .. (truck is in the lot now) We are very busy though and wont get to this untill the new year ..
currently we have a weld in of our own ..
much better than that other stuff
Old Nov 17, 2010 | 05:49 PM
2DoorRunner's Avatar
Like this? Subscribed. The best idea i have heard is simply finding a donor and replacing the sheetmetal that you need.
Old Nov 17, 2010 | 06:48 PM
slacker's Avatar
just look at the rust inbehind the holes ..
replacing sheetmetal is just a bandaid ...
Old Nov 18, 2010 | 02:27 PM
Im not going to buy your fiberglass lol
I dont mind the rust for now. I will probably end up hacking off the lower part to raise the bumper line and replace the metal i need to on the part i dont cut off.
I think AxleIke or someone show a bunch of pics in his write up. Someone correct me if im wrong.
Old Nov 18, 2010 | 04:15 PM
jbw's Avatar
jbw
Thanks, been looking at your site for the last few weeks and wondering why there were no fiberglass replacements for the 2nd gen 4runner, I can wait until after the new year. The main reason I did not consider your weld in wheelwell arches is because they don't seem to do anything to address the "dog-leg" section behind the plastic chip-gaurd thing behind the rear doors - if you remove the plastic on mine, theres not a scrap of metal left in there!
If I'm wrong, and the arch weld-ins do replace the dog-leg section then sign me up, I'd consider a pair of those in a heartbeat...you're a hell of a lot closer than Quebec too!
This is exactly what I was planning on doing..I'll search for AxleIke and see what I come up with.
Old Nov 18, 2010 | 07:14 PM
RobD's Avatar
Actually, if you look at my pic, you'll see Corey's (Slacker's) patch panel. I bought two of them from him a couple years ago and they, too, are panel bonding adhesived into place.
Old Nov 18, 2010 | 07:31 PM
Tofer's Avatar
Sponsor
every rust thread makes me so glad to live in WA.
Old Nov 18, 2010 | 07:47 PM
jbw's Avatar
jbw
cool, seems like a good way to go. I sent corey a PM asking a few questions about the dog-leg area behind the rear doors. Did you pop-rivet the arch patches as well as use the body panel adhesive, or was the adhesive enough?
Old Nov 18, 2010 | 08:16 PM
RobD's Avatar
I used nothing but adhesive. The pop rivets were only on that patch panel.
With the 3M PBA, it's said that the bond will more than likely tear the metal before the adhesive gives out.
I cut the rusty area out, cleaned up about 1" of paint from the bodypanel and from the back of the patch panel, coated with the 3M and clamped them together, forming a "lap joint".
I smoothed the edges out with a flap wheel (although it would be a better idea to do that before putting the panel on...the heat of sanding can weaken the adhesive) and used Evercoat Rage Gold bodyfiller to smooth the edges.
Old Nov 18, 2010 | 08:46 PM
UKrunner's Avatar
Nice! I have more hole than body from the dog leg to the light cluster and down under the bumper. There is a 4Runner in the junk yard here with perfect panels but they want $100 for each one and $100 to cut them out.
I'd love to replace thqt whole section from below bumper up to the crease line and over to the dog leg with fibreglass.
For $75 a side!
Old Nov 18, 2010 | 08:51 PM
Yeah, damn canadians.
Old Nov 18, 2010 | 09:10 PM
jbw's Avatar
jbw
Looks great, he should have those picture on his website!
Do you have any pictures showing the dog leg section as it wraps into the cab?
Old Nov 18, 2010 | 09:19 PM
RobD's Avatar
Do you mean the portion that goes under the rear doors?
