22re wont start after bj spacers
Old Aug 19, 2007 | 08:58 AM
red89yota's Avatar
Ok heres the problem I just did a ball joint spacer install on my 89 22re 4x4 5-speed and now it wont start it was running perect before I did the install. My fuel pump, tank and filter are only about 3 months old.
Old Aug 19, 2007 | 09:09 AM
Bear80's Avatar
not related to your work. Better define "won't start." Will the starter turn the motor over but no fire OR no stater action.
Old Aug 19, 2007 | 09:13 AM
sdstud212001's Avatar
Did you happen damage the starter while lifting it? Maybe the + wire came loose from the starter? If is a stick are you pressing the clutch all the way down?
Old Aug 19, 2007 | 09:26 AM
RustBucket's Avatar
Did you forget to use the special balljoint grease that the FSM recommends? If you don't have the right grease, then buddy, your truck is HISTORY!
Old Aug 19, 2007 | 11:21 AM
red89yota's Avatar
never mind it finally started it was just setting there spinning over guess something up with fuel pump.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
