22re thermostat housing bolts anti-seize?
Old Jul 20, 2021 | 04:02 PM
shafner30's Avatar
Going to change my thermostat soon do you guys put anti-seize on your thermostat housing bolts?on a 22re
thanks in Advance
Old Jul 20, 2021 | 04:08 PM
millball's Avatar
Application of antiseize is a good plan
. Avoid overtightening the lubricated threads.
Old Jul 20, 2021 | 05:58 PM
swampedout's Avatar
5 Year Member
Id trust Millball, tho Ive never done anti seize on this, its probably a good idea. Inspect the threads and clean em out good. You dont need to go monkey arms on these. If the tstat leaks a lil, tighten them down again.
use the rubber grommet that goes around the tstat, dont use the gasket.
Old Jul 20, 2021 | 06:42 PM
Melrose 4r's Avatar
5 Year Member
Absolutely. I just broke and had to drill out one of those thermostat housing bolts where the previous owner did not use anti-seize.
Old Jul 20, 2021 | 11:46 PM
SomedayJ's Avatar
It took me a week to release those bolts, they were very tight and I was afraid to break them, after 7 days applying penetrating oiI I could remove them. I did use anti-seize in those bolt when I put them back.
Old Jul 21, 2021 | 01:58 AM
wyoming9's Avatar
Red face
thanks in Advance
I don`t know of any 22R series engine that has not had a thermostat bolt twist off unless it was never apart.
I had put studs in a few engines which worked quite well .
I buy different anti seize by the case it goes on most anything but head bolts and the bottom end.
Hardware that thermal cycles it is even more important
chicagopetedagreek1
Nov 7, 2017 02:42 PM
Turbo87Harms88
Jan 20, 2014 06:09 PM
deano1982
May 30, 2011 06:41 AM
ugabulldog
Feb 22, 2011 01:48 PM
