22re puffs white smoke new engine!
Old Oct 5, 2008 | 06:40 PM
91Toyota's Avatar
Okay. Just rebuilt my engine. Put new gasket on intake (cleaned it off and made sure it was straight and VERY clean and the head too!) and tightened it down. Started my engine...and its puffing white smoke for a solid 2-3 minutes. No oil in antifreeze and no antifreeze in oil. Both are fine...but its using antifreeze quite a bit. Its also leaking antifreeze out of the intake. I'm guessing its leaking antifreeze into the intake...now how do I fix this? Can I put two gaskets on the intake? Put grease on the gasket?
Thanks!
Old Oct 5, 2008 | 06:42 PM
DeathCougar's Avatar
Do NOT put two gaskets on it. Grease, also no.
You need to take the intake and have it surfaced, then put a factory gasket on there. Those aftermarket POS gaskets are known to leak.
Old Oct 5, 2008 | 07:29 PM
91Toyota's Avatar
Really? Thats a lot of work for that? Is there ANY other solution? Like maybe gasket maker? Thanks
Old Oct 5, 2008 | 08:00 PM
abecedarian's Avatar
lol
rofl
roflmmfao
what did you forget to do?
Old Oct 5, 2008 | 08:01 PM
91Toyota's Avatar
Oh yeah...and I made a video of her starting for the first time:-P
Old Oct 5, 2008 | 08:02 PM
91Toyota's Avatar
Originally Posted by abecedarian
lol
rofl
roflmmfao
Seriously didn't forget to do anything. lol. Put everything back together. Torqued everything possible. Ran into a couple problems (removing pilot bearing) and thats about it. For some reason everything seems to leak on this damn truck. lol.
I've worked two days solid on this thing. I've made sure I did everything right. It starts pretty well though...just like it would normally. Just I'm pretty sure its sending antifreeze straight into the intake and need to know how to fix it. I really don't want to take my intake to the machine shop but I probably will have to. Thanks
Old Oct 5, 2008 | 08:05 PM
and the coolant heated IAV under the throttle?
*edit- sorry, just have a feeling....
Old Oct 5, 2008 | 08:07 PM
91Toyota's Avatar
What about it?
Old Oct 5, 2008 | 08:11 PM
91Toyota's Avatar
Okay I'll save you time. Yeah antifreeze probably "could" run through that straight into the intake and right into the engine. But...antifreeze is also leaking out of the top/bottom of the intake so I'm pretty sure its going straight into the engine too.
Old Oct 5, 2008 | 08:38 PM
so I guess you don't need me to point things out?
Old Oct 5, 2008 | 08:50 PM
91Toyota's Avatar
Nope...I guess not...but do I need to shave the intake and get an OEM intake gasket?
Old Oct 5, 2008 | 08:52 PM
you think?
who told you that?
not a normal thing to do, without cause.
Old Oct 5, 2008 | 11:15 PM
91Toyota's Avatar
So that would be a yes? lol
Old Oct 6, 2008 | 06:21 AM
91Toyota's Avatar
Jeez...this thread is full of white trucks
Old Oct 6, 2008 | 07:57 AM
And white smoke....
The White way, is the right way!
Old Oct 6, 2008 | 08:11 AM
yup... once you go white, you know it's right.
Old Oct 6, 2008 | 01:12 PM
91Toyota's Avatar
Haha! Anyway...I took off the upper intake plenum and coolant is just sitting in the #1 runner (closest to the front of the truck). I bought a new gasket...and WOW...its definitely "better" in terms of it has rubber type rings around each hole and looks like it will actually hold something. Looks like OEM wins again! ha!
Old Oct 6, 2008 | 01:16 PM
91Toyota's Avatar
My brother told me my truck wouldn't start haha! I knew I wasn't TOTALLY incapable of putting my truck back together...LOL. Jackass makes in fun of me
Colington
Mar 8, 2020 09:51 AM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
raiderhawks00
Jul 8, 2015 06:23 PM
