22re power surges
Old Apr 21, 2007 | 09:20 AM
jetpilot's Avatar
22re power surges
Please help.....I have an 87 pickup with a 22re. While driving the motor constantly loses and gains power. When parked, i try to maintin a constant rpm but again it surges. While experiencing a loss of power it runs really rough and idles a few hundred rpm lower than normal. I have recently replaced the TPS, fuel filter, cap, rotor and spark plugs. When checking the trouble codes it shows everything normal.
Old Apr 21, 2007 | 09:27 AM
thook's Avatar
Does it change at all with the motor hot or cold?
Old Apr 21, 2007 | 09:46 AM
jetpilot's Avatar
No, and it starts fine hot or cold
Old Apr 21, 2007 | 11:39 AM
90_yota's Avatar
i had almost the same situation and after workin at everything else i found out i had a broken and worn out timing chain slide.installed new timing set and it ran as good as new.
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
