22re missing unless disconnect egr
Old Oct 5, 2011 | 10:50 PM
japjeep's Avatar
help!! have an 86 22re and cant find engine miss. if i remove the vacum line from the egr valve it goes away and runs great. anyone have any experiance with this?
Old Oct 10, 2011 | 01:15 PM
fissure333's Avatar
what 4crawler said.
Old Oct 10, 2011 | 01:23 PM
4Crawler's Avatar
Since puling the vacuum line corrects the problem, it is unlikely the EGR is stuck open as it would be stuck open with or w/o vacuum to it.
Likely that the EGR modulator is plumbed incorrectly and commanding the EGR to open when it should not. Check the lines off the throttle body and the BVSV under the TB to see if those lines are hooked up correctly per the FSM. They are all labelled with letters to indicate where they connect to.
montanatruck
Feb 26, 2017 07:07 AM
montanatruck
Jul 25, 2015 03:45 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Odin
Jul 15, 2015 09:28 PM
ryerye13
Jul 14, 2015 08:27 AM
