a 22re, and the disappearing oil mystery...
Old Jan 27, 2010 | 11:00 AM
  #41
misterzee's Avatar
You're not alone SB, we rebuilt Rustbucket's 22re, and its been like a new one since, other than a bit of a weird knock... I rebuilt mine, same care, and went through the break in steps. Now, with close to 15,000 miles on it, I still dump a quart of oil in every 500 miles minimum. I had to change the sparkplugs recently because of all the buildup on em. Weird.
I have another new 22re I'm going to drop in this spring, and then we'll find out whats wrong when I tear this one back apart.... I'll let ya know.
Old Feb 18, 2010 | 02:32 AM
  #42
flyingbrass's Avatar
This is just a shot in the dark, but I thought I'd mention it. Could a leaky baffle gasket in the valve cover be allowing oil to be sucked in through the PCV system?
Most rebuilders clean the valve cover, sometimes *very* thoroughly, maybe even enough to compromise that gasket. Parts of mine flushed out. If oil can get slopped up top near the PCV valve, seems to me that this could be a problem.
Old Feb 18, 2010 | 06:18 AM
  #43
rangerruck's Avatar
that's interesting; the top of my cover allways seems to be damp with oil...
Old Mar 22, 2010 | 08:30 PM
  #44
Any updates, Bleeder?
I plan to fire up my rebuild the day after tomorrow. This thread has been sticking in the back of my mind.
Old Mar 22, 2010 | 08:40 PM
  #45
yotaman85's Avatar
did you baby your motor when it was first put together? if you did thats why you are using oil, your rings arnt set properly yet. it may take up to 10k miles before your rings will set i you dont pressure set them in the first place.
Old Mar 22, 2010 | 09:09 PM
  #46
Just curious, and this probably isn't related, but what did your ring gaps measure?
Old Mar 23, 2010 | 03:04 PM
  #47
Jay351's Avatar
Originally Posted by iamsuperbleeder
lol, I had a friend who did that with an old Mazda 323 he had
through a combination of leaks and burning it, that car used as much oil as it did gas almost so he'd top it off every time he filled up with gas, and every so often he'd change the filter
to my knowledge, he NEVER changed the oil on that car once it's started loosing oil, and he drove it for AT LEAST 4 years like that through high school
Ha!
A friend of mines mid 90's dodge 318 4x4 used to be like that. Fill up the oil and check the gas
Old Mar 23, 2010 | 03:42 PM
  #48
iamsuperbleeder's Avatar
right now, I switched to the 15w40, and have stuck with that, and it seems to be going through less; about 1 to 1 1/2 quarts between oil changes
well, it idled for probably 10 minutes after first startup, then I drove it like I stole it down to the gas station (with the hood off still ) because it was running on fumes, and stayed pretty hard on it for the next few days.
oh man, I honestly don't remember... I didn't write them down but they were in spec
Old Mar 23, 2010 | 05:01 PM
  #49
Teuf's Avatar
isn't 15 w an impediment to good start up oil flow?
Old Mar 23, 2010 | 05:11 PM
  #50
actually it made the motor more quiet during startups when it's cold
Old Mar 23, 2010 | 05:24 PM
  #51
Teuf's Avatar
that may be,..... flow = cooling =longer life?
smthwsn357
May 1, 2024 07:28 AM
raptor510
Feb 17, 2017 07:11 AM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
ryerye13
Jul 14, 2015 08:27 AM
