22RE crank pulley
Old Apr 27, 2008 | 05:15 PM
DanStew's Avatar
22RE crank pulley
Does the pulley press on and off the harmonic balancer? I have a second harbonic balancer that isnt damaged but it has a 2 groove pully on it, and my motor has a 3 groove for the AC. I see botls on the front, jsut want to make sure it can be pressed off before i try.
Old Apr 27, 2008 | 05:18 PM
4runnerx3's Avatar
They bolt together.
Old Apr 27, 2008 | 05:23 PM
DanStew's Avatar
Thanks. Makes life easier.
Old Apr 28, 2008 | 03:52 PM
iamsuperbleeder's Avatar
https://www.yotatech.com/forums/f116...y-22re-142197/
Old Apr 28, 2008 | 04:27 PM
thook's Avatar
The first two-row pulley slides on and off over the keyway on the crankshaft in front of the harmonic balancer....not onto it. The balancer is encircled by the main seal seated in the oil pump housing. Then, the a/c pulley bolts on to the two-row.
If you're trying to remove the two-row pulley, you may need a puller if it's frozen up. Then again, it may just slide right off with some gentle tapping.
yoterr
Jul 24, 2015 04:29 AM
PlayAwhile
Jul 20, 2015 11:36 AM
redneck17
Jul 17, 2015 07:44 PM
dinks07
Jul 15, 2015 05:34 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
