22RE crank but no start - got fuel and spark
Old 03-01-2009, 03:35 PM
abecedarian's Avatar
Have you ever removed the TPS from the throttle body?
Old 03-01-2009, 03:51 PM
scharp's Avatar
i tested the top two which from the diagram was IDL and E2 so i thought, no i havent taken the TPS off the throttle body
Old 03-01-2009, 04:36 PM
934rnr's Avatar
Checked your intake tube or the AFM? I don't think the tps is the problem because it will run without the tps(not very good) but not the afm.
I just went through the same sort of thing. However it turned out to be a bad clogged fuel filter.
Could be water in your gas too check the code 12 post.
Old 03-01-2009, 04:38 PM
If you're looking at the TPS while installed on the throttle body, and the connector comes in from the left:
*thanks 4Crawler for the image.
Old 03-01-2009, 04:40 PM
  #25
the code 11 specifically relates to the IDL terminal (says so in the code definition) on the TPS and you didn't test it?
Old 03-01-2009, 04:59 PM
  #26
scharp's Avatar
well i thought i did test it i guess i tested the wrong terminals
Old 03-01-2009, 05:04 PM
  #27
scharp's Avatar
well i tested the top two terminals not the bottom two, so i tested to wrong two terminals
Old 03-01-2009, 05:23 PM
  #28
you said that already.
and....?
Old 03-01-2009, 05:27 PM
  #29
scharp's Avatar
well i havent tested it yet on the right ones, ima do it first thing in the morning, and i will let you know. and yea i didnt mean to post that twice
Old 03-01-2009, 05:44 PM
  #30
Good luck.
If I'm not here to help, I'm sure one of the other YotaTech members will.
Old 03-01-2009, 05:47 PM
  #31
scharp's Avatar
ok thanks for helping me this far. i really appreciate it
Old 03-01-2009, 06:25 PM
  #32
scharp's Avatar
my buddy is helpin me troubleshoot the truck and he keeps finding fuel pump. like the fuel pump is not producing enough pressure to start the engine
Old 03-01-2009, 06:26 PM
  #33
put a pressure gauge on the fuel line before the regulator and post the pressure.
Old 03-01-2009, 06:43 PM
  #34
scharp's Avatar
will do.
Old 03-02-2009, 03:15 PM
  #35
scharp's Avatar
its got good pressure. but i couldnt put a gauge on it cuz i couldnt find the right adapter to check it
Old 03-02-2009, 03:39 PM
  #36
jimep's Avatar
Sounds similar to a problem I was having. I had fuel pressure and spark but it wouldn't even fire. I could get it to start on starting fluid just by spraying some in the intake but that was it. first thing I checked was the injectors. They weren't opening. Test for voltage to ground at the wiring harnes plug with the key on. Should get close to 12 volts. If nothing start working towards the injector resistor or ignition. (injectors are grounded in ecu when told to fire) . If you get 12 volts then crank it with a noid light in and see if it flashes. thats my 2 cents. Hope it helps
The following users liked this post:
1stgen503 (04-14-2020)
Old 03-02-2009, 05:02 PM
  #37
scharp's Avatar
i tried some starting fluid and it still wouldnt start
Old 03-02-2009, 05:09 PM
  #38
annoyingrob's Avatar
Was this motor running before? If so, what did you mess with.
Old 03-02-2009, 05:11 PM
  #39
scharp's Avatar
yea, i havent messed with anything
Old 03-03-2009, 02:37 PM
  #40
scharp's Avatar
i put a noid light on it and its good on the flash. im thinkin injectors. has anyone had injectors take a with 90000 miles?
Quick Reply: 22RE crank but no start - got fuel and spark
