22RE - Air/Fuel Mixture Screw on Throttle Body Turning Itself
Old May 25, 2015 | 10:51 PM
stanz's Avatar
I'm finding that my mixture screw is turning itself as I drive. It's rotated as much as 120 degrees (close to a full half turn) in a single trip. I'm also concerned if it's that loose that it's creating a vacuum leak.
Curious how to go about solving this. Thoughts?
Old May 25, 2015 | 11:19 PM
Robert m's Avatar
The screw on the TB is the idle adjustment screw. If you pull the screw out, it has an O ring on it that seals it and holds it in place. Replace the O ring and put it back in. My local napa had one that fit perfect and it cost me like .50
Old May 26, 2015 | 04:53 AM
my_83toy's Avatar
temporary fix
you can wrap three layers of Teflon tape around that until you're able to replace your oring
Old May 26, 2015 | 06:41 PM
osv's Avatar
osv
the o-ring replacement is the right idea, but you can also cover it entirely with rtv.
Jun 1, 2021 01:51 PM
smiley52
Jul 11, 2015 05:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
