1995 pickup 4x4 3.0l v6 automatic - coolant leak behind water pump pulley -
Old Jun 4, 2017 | 08:35 AM
Toyoda902's Avatar
Hey guys and gals. Having an issue with a bad coolant leak behind the water pump pulley area. Anyone have any ideas / suggestions?
Old Jun 4, 2017 | 09:09 AM
dropzone's Avatar
Fossilized
replace it. The part that sucks is the water pump is mounted behind the timing belt on a 3.0. Might has well do the timing belt, thermostat, hoses and pump while you are in there
Old Jun 4, 2017 | 09:16 AM
Toyoda902's Avatar
Downside to replacing it... I just replaced the timing belt and idler pulley and tensioner and had it timed and put back together 😪 So in other words my luck has Sh** on me again😂.
Old Jun 4, 2017 | 10:02 AM
dropzone's Avatar
Fossilized
and you didn't replace the pump while you had it all opened up?
Old Jun 4, 2017 | 10:34 AM
Toyoda902's Avatar
Didnt have an issue with the water pump untill now, thats why it wasnt replaced. If its not broke dont fix it had a factor in there also.
Old Jun 4, 2017 | 01:13 PM
scope103's Avatar
Yeah, but you got to practice removing a timing belt! This time, you'll be in an out in what, 10 minutes?
Old Jun 4, 2017 | 01:20 PM
Toyoda902's Avatar
With a few cus words yes is can take me 10 min. By the looks of it i can do it without completely taking the belt off. Thanks all for you help!
