1994 pickup 4x4 22re rear brake shoes
Old Dec 6, 2017 | 03:38 PM
acudadude's Avatar
Hi Need to replace my oem rear shoes on my 94 pickup 4x4 ,still running the oem factory shoes . What do u guys recommend for replacement toyota oem or other brands such as raybestos,wagner ,or ??? What the best place online to order the oem toyota shoes ...thks for the help
Old Dec 6, 2017 | 07:09 PM
RAD4Runner's Avatar
I don't know about your model but on our first-gen 4Runner OEM brake shoes have been discontinued. I am perfectly happy with the $17/pair shoes and $16each rear cylinders from NAPA. If it would help your decision, very little braking power is provided by rear brakes; most of the braking is done by fronts.
Also, just a heads-up: I suggest you make sure you have readily-available brake cylinders or rebuild supplies and tools, just in case. If you still have the original shoes, deteriorated brake fluid, and rusted/pitted brake cylinders may cause a leak. Why it happens explained here: https://www.yotatech.com/forums/f116...l#post52373259
Old Dec 7, 2017 | 12:17 AM
wyoming9's Avatar
Red face
Don`t forget Drums as well
I like the Napa Ultra Premium Line of brake parts
It seems doing the rear brakes can be an adventure at least here in the Northeast .
Don`t forget to back the adjuster off to get the drums off easier
Making sure once things are apart the adjusters are cleaned and lubed working like they should
Old Dec 7, 2017 | 07:10 AM
acudadude's Avatar
Thanks guys for the help will look into napa stuff ,gotta pull wheel to get drum size looks like 11'' or 10''
Old Dec 8, 2017 | 03:35 PM
acudadude's Avatar
I picked up a set of shoes from Autozone for $17 gonna put those on for now till i save up for one of those complete kits shoes,cyls,drums, springs..they were cheap enough to play with will post a pic soon thks
Old Dec 15, 2017 | 12:10 PM
anndel's Avatar
I bought NAPA Premium replacement drums and Toyota OEM brake shoes, hardware.
scott.475
Jan 28, 2007 08:47 AM
