1994 2WD front brake upgrade/swap
Old Sep 9, 2010 | 09:45 AM
Chip Morto's Avatar
Hey all! I've been reading this great forum for a while. I recently did the top end and clutch on my 1994 2WD truck and a lot of what helped was stuff I read here. Thank you!
So as my first post, and I did a search but didn't find my specific case, is that I'm looking to improve the front brakes on my truck. It has the little whimpy single piston floating calipers. I know I've seen other write ups on some other models of Toyota trucks and Land Crisers that bolt right up with little problem.
Does anyone know if there is a four piston caliper that will bolt onto the existing brackets? I'm fine with a little backing plate trimming and minor stuff but I'd rather not have to get into fabricating brackets.
Thanks!!
Old Sep 9, 2010 | 03:40 PM
Robert m's Avatar
try searching over on toyotaminis.com
there was a guy making 4piston caliper brackets for the 2wds.
Old Sep 9, 2010 | 04:24 PM
JamesD's Avatar
X2
Supra brake conversion as well. Go there and you will find
James
Old Sep 9, 2010 | 10:28 PM
Chip Morto's Avatar
Thank you very much, gentlemen, I'll check it out.
Much appreciated!
Old Sep 10, 2010 | 07:43 PM
GUATEMALARON's Avatar
Shift on the fly
Does anyone know if my 1994 has shift on the fly 4x4?
Old Jan 31, 2011 | 12:07 PM
hilandfrog's Avatar
2 to 4 hi yes
I know nothing of your hubs
repo
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Doug4320
Mar 24, 2018 10:11 PM
Road Bull
Oct 10, 2015 04:55 PM
Sep 4, 2015 09:27 AM
